Welcome to WIZnet Developer Forum
The first paragraph of this pinned topic will be visible as a welcome message to all new visitors on your homepage. It’s important!
Edit this into a brief description of your community:
  • Who is it for?
  • What can they find here?
  • Why should they come here?
  • Where can they read more (links, resources, etc)?
You may want to close this topic via the admin :wrench: (at the upper right and bottom), so that replies don’t pile up on an announcement.
Hello, I’m new on this forum. I’m with my team researching opportunity to upgrade some existing and manufactured industrial instruments equipped with typical MODBUS RTU over RS485 have in first stage inbuilt MODBUS TCP and further web server etc.
Sir,
We are using W5500 in an application and are setting internet parameters like
IP setup: Static or DHCP
IP address
Netmask (submask)
port number
etc through the UART port of the support micro controller.
Can we know if the above parameters can be set directly through the ETHERNET PORT ITSELF onto the on board W5500 directly.
Regards
VTC
