SSL example with certificate
I like to show how to connect ssl server with certificate using WizFi210.
Generally, to connect , you don’t need , and demand .
As a example, to connect , you need
which Apple issued to you.
Anyway, here is a example about using WizFi210.
Step1) Add Certificate File
Step2) AP Association and Set Time
[quote]AT+WD
[OK]
AT+NDHCP=1
[OK]
AT+WWPA=12345678
[OK]
AT+WA=WizFiDemoAP
IP SubNet Gateway
192.168.3.101: 255.255.255.0: 192.168.3.1
[OK]
AT+SETTIME=04/09/2013,13:11:11
[OK]
[/quote]
Step3) SSL Connect
[quote]AT+NCLOSEALL
[OK]
AT+NCTCP=17.172.xxx.xx,2195
[CONNECT 0]
[OK]
AT+SSLOPEN=0,rootca,usercert,userkey
[OK]
[/quote]
About <AT+TCERTDEL>, <AT+TCERTADD> and <AT+SSLOPEN> refer to the WizFi210 Programmer’s Guide.
About certificate file type and conversion, refer to the below site.
[url]
http://www.openssl.org/[/url]
Regards, Steve
