I am trying to do DHCP with a W5500 chip. I am able to send a DHCP discovery message and the DHCP server responds with a DHCP Offer message but the W5500 chip never receives this message (I have checked this with wireshark). I am using FreeRTOS and ESP32. The problem seems to be in getSn_RX_RSR as it always returns 0 so the software never tries to receive data from the chip. I hope you can help me.
Thanks,
Lorien
WIZCHIP_INIT(); // This is SPI configuration
gpio_pad_select_gpio(RST_ETH); // Hard reset W5500
gpio_set_direction(RST_ETH, GPIO_MODE_OUTPUT);
gpio_set_level(RST_ETH, 0);
vTaskDelay(500);
gpio_set_level(RST_ETH, 1);
vTaskDelay(500);
wizchip_sw_reset();
vTaskDelay(200);
uint8_t tmp;
do {
printf("Unknown PHY Link status.\r\n");
} while(tmp == PHY_LINK_OFF);
if(ctlnetwork(CN_SET_NETINFO, (void*) &gWIZNETINFO) < 0) {
printf("FAILED TO SET NETWORK INFO\n");
xTaskCreate(W5500_timer_task, "W5500_TIMER_TASK", 1024, NULL, 3, &dhcp_timer_task_handle);
if(gWIZNETINFO.dhcp == NETINFO_DHCP) {
uint8_t * buffer = malloc(2048);
DHCP_init(SOCK_DHCP, buffer);
reg_dhcp_cbfunc(0, 0, 0);
while(1) {
uint8_t res = DHCP_run();
if(res != 1) printf("RES: %d\n", res);
switch(res) {
case DHCP_IP_ASSIGN:
printf("DHCP_IP_ASSIGN!\n");
case DHCP_IP_CHANGED:
printf("DHCP_IP_CHANGED!\n");
break;
case DHCP_IP_LEASED:
printf("DHCP_IP_LEASED!\n");
break;
case DHCP_FAILED:
printf("DHCP_FAILED!\n");
my_dhcp_retry++;
if(my_dhcp_retry > 20) {
DHCP_stop(); // if restart, recall DHCP_init()
#ifdef _MAIN_DEBUG_
printf(">> DHCP %d Failed\r\n", my_dhcp_retry);
#endif
my_dhcp_retry = 0;
return -1;
break;
default:
break;
return 0;
