I hope you can understand my question. I’ve tried to make this as simple and clear cut as I can. I need to get the DNS IP address assigned to my WIZFI630 module using serial commands. I am hardwired (via Ethernet cable) to my DSL router. My DSL router assigns to my WIZFI630 module a Primary DNS Server IP and a Secondary DNS Server IP. I am needing to obtain those assigned IP addresses using the serial port command interface provided by the WIZFI630 module. See below pics for specifics:
Thanks!
