안녕하십니까?
TCP 통신과 UDP 통신을 선택해서 사용하고 싶습니다.
TCP 통신은 되는데 UDP 통신을 안됩니다.
어떻게 하면 되는지 부탁드립니다. 감사드립낟.
제가 사용하는 함수는 아래와 같습니다.
u8 gu8_Tcp_Tx_Buf[DATA_BUF_SIZE]; // TX Buffer for applications
void loopback_tcpc(SOCKET s, uint16_t port)
uint16_t RSR_len;
uint16_t received_len;
switch (getSn_SR(s))
case SOCK_ESTABLISHED: /* if connection is established */
if(ch_status[s]==1)
//printf("\r\n%d : Server IP : %d.%d.%d.%d , Port : %d Connected",s,Destination_Setup.destip[0],Destination_Setup.destip[1],Destination_Setup.destip[2],Destination_Setup.destip[3],Destination_Setup.port);
ch_status[s] = 2;
if ((RSR_len = getSn_RX_RSR(s)) > 0) /* check Rx data */
if (RSR_len > DATA_BUF_SIZE) RSR_len = DATA_BUF_SIZE; /* if Rx data size is lager than TX_RX_MAX_BUF_SIZE */
/* the data size to read is MAX_BUF_SIZE. */
gu8_Tcp_RxBuf_Length = recv(s, gu8_Tcp_Rx_Buf, RSR_len); /* read the received data */
// TCP_Parsing(s);
gu8_SerialOrNetwork = 2;//Network Mode
RxData_Parsing(gu8_Tcp_Rx_Buf,gu8_Tcp_RxBuf_Length);
break;
case SOCK_CLOSE_WAIT: /* If the client request to close */
printf("\r\n%d : CLOSE_WAIT", s);
received_len = recv(s, gu8_Tcp_Rx_Buf, RSR_len); /* read the received data */
disconnect(s);
ch_status[s] = 0;
break;
case SOCK_CLOSED: /* if a socket is closed */
if(!ch_status[s])
//printf("\r\n%d : Loop-Back TCP Client Started. port: %d", s, port);
ch_status[s] = 1;
if(socket(s, Sn_MR_TCP, Destination_Setup.port, 0x00) != s) /* reinitialize the socket */
//printf("\a%d : Fail to create socket.",s);
ch_status[s] = 0;
break;
case SOCK_INIT: /* if a socket is initiated */
if(sys_tick_cnt == 0)
if(connect(s, Destination_Setup.destip, Destination_Setup.port) == 1) /* Try to connect to TCP server(Socket, DestIP, DestPort) */
//printf("\r\nconnect port: %d", port);
sys_tick_cnt = 100;
break;
default:
break;
