Here is my code which Iam using. kindly go through the same.
Main()
uint16 data_buf = (uint16) 0xC000; // buffer for loopback data
wiz_sysinit ();
while (1)
loopback_udp (7, 200,data_buf, 0); // using socket 7
INSIDE MAIN FN I am calling this
Wiznet intialisation
void wiz_sysinit (void)
//----------WIZNET 5300 CONFIGURATION SECTION -----------------------//
*(vuint16 *)MR0 = 0x38;
*(vuint16 *)MR1 = 0x00;
*(vuint16 *)IMR0 = 0x00;
*(vuint16 *)IMR1 = 0x00;
*(vuint16 *)SHAR0 = 0x00; // MAC address
*(vuint16 *)SHAR1 = 0x08;
*(vuint16 *)SHAR2 = 0xDC;
*(vuint16 *)SHAR3 = 0x01;
*(vuint16 *)SHAR4 = 0x02;
*(vuint16 *)SHAR5 = 0x03;
*(vuint16 *)GAR0 = 0xC0; // Gateway IP address 192.168.0.1
*(vuint16 *)GAR1 = 0xA8;
*(vuint16 *)GAR2 = 0x00;
*(vuint16 *)GAR3 = 0x01;
*(vuint16 *)SUBR0 = 0xFF; // SUBNET MASK 255.255.255.0
*(vuint16 *)SUBR1 = 0xFF;
*(vuint16 *)SUBR2 = 0xFF;
*(vuint16 *)SUBR3 = 0x00;
*(vuint16 *)SIPR0 = 0xC0; // SOURCE IP 192.168.0.3
*(vuint16 *)SIPR1 = 0xA8;
*(vuint16 *)SIPR2 = 0x00;
*(vuint16 *)SIPR3 = 0x03;
*(vuint16 *)TMSR0 = 0x08; // TX MEM SIZE EACH SOCKET
*(vuint16 *)TMSR1 = 0x08;
*(vuint16 *)TMSR2 = 0x08;
*(vuint16 *)TMSR3 = 0x08;
*(vuint16 *)TMSR4 = 0x08;
*(vuint16 *)TMSR5 = 0x08;
*(vuint16 *)TMSR6 = 0x08;
*(vuint16 *)TMSR7 = 0x08;
*(vuint16 *)RMSR0 = 0x08; // RX MEM SIZE EACH SOCKET
*(vuint16 *)RMSR1 = 0x08;
*(vuint16 *)RMSR2 = 0x08;
*(vuint16 *)RMSR3 = 0x08;
*(vuint16 *)RMSR4 = 0x08;
*(vuint16 *)RMSR5 = 0x08;
*(vuint16 *)RMSR6 = 0x08;
*(vuint16 *)RMSR7 = 0x08;
*(vuint16 *)MTYPER0 = 0xFF; // TX MEMORY
*(vuint16 *)MTYPER1 = 0x00; // RX MEMORY
*(vuint16 *)RTR0 = 0x0F; // Retransmission time out , 400ms
*(vuint16 *)RTR1 = 0x0A;
*(vuint16 *)RCR0 = 0x00; // Retransmission counter, 07
*(vuint16 *)RCR1 = 0x07;
/******** UDP loopback program*****/
void loopback_udp(SOCKET s, uint16 port, uint16* buf, uint16 mode)
uint32 len=0;
uint16 destip[4];
uint16 destport;
switch(getSn_SSR(s))
case SOCK_UDP: //
if((len = getSn_RX_RSR(s)) > 0) // check the size of received data
len = recvfrom(s,buf,len,destip,&destport); // receive data from a destination
sendto(s,buf,len,destip,destport);
break;
case SOCK_CLOSED:
close_socket(s); // close the SOCKET
socket(s,Sn_MR_UDP,port,mode);//open the SOCKET with UDP
break;
default:
break;
Function definitions for the above functions are given below
uint8 getSn_SSR(SOCKET s)
uint8 ssr, ssr1;
ssr = (uint8)IINCHIP_READ(Sn_SSR1(s)) & 0x00FF; // first read
while(1)
ssr1 = (uint8)IINCHIP_READ(Sn_SSR1(s))& 0x00FF; // second read
if(ssr == ssr1)
break; // if first == second, Sn_SSR value is valid.
ssr = ssr1; // if first <> second,
return ssr;
uint32 getSn_RX_RSR(SOCKET s)
uint32 received_rx_size=0;
uint32 received_rx_size1=1;
uint32 a=0,b=0,c=0,d=0;
uint32 e=0,f=0,g=0;
e = IINCHIP_READ(Sn_RX_RSR0(s));
a = (e<<24);
f = IINCHIP_READ(Sn_RX_RSR1(s));
b = (f<<16);
g = IINCHIP_READ(Sn_RX_RSR2(s));
c = (g<<8);
d = IINCHIP_READ(Sn_RX_RSR3(s));
while(1)
received_rx_size = ((b & 0x00FF0000) | (c & 0x0000FF00) | (d & 0x000000FF));
if(received_rx_size == received_rx_size1)
break;
received_rx_size1 = received_rx_size;
return received_rx_size;
uint16 IINCHIP_READ(uint32 addr)
return *(vuint16 *)addr;
uint8 socket(SOCKET s, uint8 protocol, uint16 port, uint16 flag)
IINCHIP_WRITE(Sn_MR1(s),(uint16)(protocol | flag));
IINCHIP_WRITE(Sn_PORTR1(s),port); //
setSn_CR(s, Sn_CR_OPEN); // open s-th SOCKET
check_sendok_flag[s] = 1; // initialize the sendok flag.
return 1;
void IINCHIP_WRITE(uint32 addr,uint16 data)
*(vuint16 *)addr = data;
void setSn_CR(SOCKET s, uint16 com)
IINCHIP_WRITE(Sn_CR1(s),com); //
while(IINCHIP_READ(Sn_CR1(s))); // wait until Sn_CR is cleared.
void close_socket(SOCKET s)
setSn_IR(s ,0x00FF); // Clear the remained interrupt bits.
setSn_CR(s ,Sn_CR_CLOSE); // Close s-th SOCKET
uint8 getSn_IR(SOCKET s)
return (uint8)IINCHIP_READ(Sn_IR1(s)); //
uint32 sendto(SOCKET s, uint16 * buf, uint32 len, uint16 * addr, uint16 port)
uint16 status=0;
uint16 isr=0;
uint32 ret=0;
if (len > getIINCHIP_TxMAX(s)) // check size not to exceed MAX size.
ret = getIINCHIP_TxMAX(s);
else
ret = len;
IINCHIP_WRITE(Sn_DIPR0(s),192); // 192
IINCHIP_WRITE(Sn_DIPR1(s),168); // 168
IINCHIP_WRITE(Sn_DIPR2(s),0); // 0
IINCHIP_WRITE(Sn_DIPR3(s),10); // 10
IINCHIP_WRITE(Sn_DPORTR1(s),100); // 100
wiz_write_buf(s, buf, ret);
setSn_TX_WRSR(s,ret);
setSn_CR(s, Sn_CR_SEND);
while (!((isr = getSn_IR(s)) & Sn_IR_SENDOK))// wait SEND command
status = getSn_SSR(s)
if ((status == SOCK_CLOSED) || (isr & Sn_IR_TIMEOUT))
setSn_IR(s,Sn_IR_TIMEOUT);
return 0;
setSn_IR(s, Sn_IR_SENDOK); // Clear Sn_IR_SENDOK
return ret;
uint32 wiz_write_buf(SOCKET s,uint8* buf,uint32 len)
uint32 k=0;
uint32 r_val;
uint32 r_val1;
if (len%2==0) // length is even number
len = len/2 ;
else
len = (len +1)/2 ;
for (k = 0; k < len; k++)
IINCHIP_WRITE(0x2003EE,*((uint16*)(buf)));
IINCHIP_WRITE(0x2003EF,*((uint16*)(buf+1)));
buf = buf + 2;
return len;
void setSn_TX_WRSR(SOCKET s, uint32 size)
IINCHIP_WRITE(Sn_TX_WRSR0(s), (uint16)(size >> 24));
IINCHIP_WRITE(Sn_TX_WRSR1(s), (uint16)(size >> 16));
IINCHIP_WRITE(Sn_TX_WRSR2(s), (uint16)(size >> 8)) ;
IINCHIP_WRITE(Sn_TX_WRSR3(s), (uint16)size);
uint32 recvfrom(SOCKET s, uint16 * buf, uint32 len, uint16 * addr, uint16 *port)
uint16 head[10];
uint32 data_len=0;
if ( len > 0 )
switch (IINCHIP_READ(Sn_MR1(s)) & 0x07)
case Sn_MR_UDP : // UDP mode
wiz_read_buf(s, (uint8*)head, 8);
*port = ((head[5]<<8)& 0xFF00)|head[4]; // destination port
data_len = ((head[7]<<8)& 0xFF00)|head[6];// DATA
wiz_read_buf(s, buf, data_len); // data copy.
setSn_CR(s,Sn_CR_RECV); // recv
break;
default:
break;
return data_len;
uint32 wiz_read_buf(SOCKET s, uint8* buf,uint32 len)
uint32 k;
len = len/2 ;
else
len = (len +1)/2 ;
*((uint16*)(buf)) = IINCHIP_READ(0x2003F0);
*((uint16*)(buf+1)) = IINCHIP_READ(0x2003F1);
buf = buf + 2;
return len;}
