micklz
April 28, 2014, 12:37pm
1
I’m trying to get W5200 to connect to the internet without results.
SPI works fine. The chip version is ‘3’.
Voltage at any pin is the same like in WIZ820io R1.0.
I have absolutely no link between chip and the pc/router.
I used transformer: tme.eu/pl/Document/3b4751156 … trafot.pdf .
This transformr works fine with WIZ820io R1.0.
Maybe it is problem with hardware?
i61.tinypic.com/2vmasrr.png
i60.tinypic.com/2ywsj9h.png
i60.tinypic.com/24p002c.png
I think your schematic & Hardware may be ok.
Check the switch on/off connected with LINKLED/SPDLED/DUPLED/MODE3.
The switch should be always on.
micklz
April 29, 2014, 6:19am
3
Thank you for your response.
RA1 and RA2 are resistor arrays. They are always on
Datasheet resistor arrays:
tme.eu/pl/Document/75bd3f016 … dr1206.pdf
Best regards.
micklz
April 30, 2014, 10:10am
4
This may be helpful:
the value from PHY register is 0x07.
Any idea?
You mean 0x07 the value of PSTATUS at 0x0035?
If yes, PHY Link is off.
It maybe your hardware have some problem?
Check the hardware validation again.
Assemble part & value,
Is Reset, Clock siginal worked?
etc…
Hello!
Did you solve this problem with no link?
Best Regards!
Patryk
micklz
February 12, 2015, 2:51pm
7
Unfortunately not.
Do you have the same problem?
Did you guys ever solved this?? I’m also facing the no link problem…
Regards,
Martijn
