Hi, I’ve designed a board with TWO W5300 on it,
I used a 25MHz crystal oscillator for each.(
CRYSTAL 25.0MHZ 18PF 20ppm 100 ohm, SMD , MANF PN:ABLS-25.000MHZ-B2F-T)
when I started the hardware test I had no Clock on Xtal Pins, I tried changing Xtal Capacitors by values of 13PF,18PF, 22PF, 33PF, 46PF and 56PF
Now one of them oscillates with 46PF capacitor installed but the other has no oscillation.
I tried changing that Xtal with NTK 25MHz Xtal but also have Problem with it,
Please help me to rectify this problem.
