Hello
Are there binaries available for the W7200 on the iMCU7200EVB other than the loopback test?
I’m investigating in a TCP/IP to serial solution anf have been test the W7100 on a WIZ107. The SW available there made a test quick and easy. Is there anything similar for the W7200?
Can I also use the WIZ127 sw?
By the way: The application is to provide a remote access over TCP/IP to serial port for the purpose of configuring a device. Which solution would you recommend: W7100A or W7200?
Regards,
LPS
