W5500 - RPi Pico
Hi. Has anyone attempted to connect W5500 through RPi Pico SPI interface?
Hello, I’ve tested it before. How are you doing the development environment?
Please refer to as below link, I tested after adding W5500 in SPI folder.
This post is written in Korean, but you can check the operation.
https://blog.naver.com/roruca/222299887109
Thanks for solving!
Hi again. I’m running your example code on the Pico and noticed that W5500 resets the Pico every 12-24 hours. I’m running you example code without modifications on a breadboard . I connect it to a another computer that make a PUTTY connection and keeps it open. Have you seen this behavior?
