ATSAMD51- 아두이노 호환 보드와 와 Wizfi 360 모듈을 사용 중 입니다.
WizFi360_arduino_library 사용에 문제가 있어 문의 드립니다.
컴파일 에러 메시지 입니다.
In file included from /home/lim/Projects/arduino-nightly/portable/sketchbook/libraries/WizFi360_arduino_library-master/src/utility/WizFi360Drv.h:26:0,
from /home/lim/Projects/arduino-nightly/portable/sketchbook/libraries/WizFi360_arduino_library-master/src/WizFi360.h:30,
from /tmp/arduino_modified_sketch_377774/ConnectWPA.ino:9:
/home/lim/Projects/arduino-nightly/portable/sketchbook/libraries/WizFi360_arduino_library-master/src/utility/RingBuffer.h:23:7: error: using typedef-name 'RingBuffer' after 'class'
class RingBuffer
In file included from /home/lim/Projects/arduino-nightly/portable/packages/robohat/hardware/samd/0.0.26/cores/arduino/Uart.h:23:0,
from /home/lim/Projects/arduino-nightly/portable/packages/robohat/hardware/samd/0.0.26/variants/arccom_m4/variant.h:47,
from /home/lim/Projects/arduino-nightly/portable/packages/robohat/hardware/samd/0.0.26/cores/arduino/delay.h:24,
from /home/lim/Projects/arduino-nightly/portable/packages/robohat/hardware/samd/0.0.26/cores/arduino/Arduino.h:81,
from /tmp/arduino_build_558587/sketch/ConnectWPA.ino.cpp:1:
/home/lim/Projects/arduino-nightly/portable/packages/robohat/hardware/samd/0.0.26/cores/arduino/RingBuffer.h:57:41: note: 'RingBuffer' has a previous declaration here
typedef RingBufferN<SERIAL_BUFFER_SIZE> RingBuffer;
일단은 아두이노 코어의 링버퍼 클래스와 WizFi360_arduino_library의 클래스가 중복되어 나타나는 현상 같은데 대처 방안을 알려 주시면 감사하겠습니다.
