W5500 httpclient get file download
httpclient 파일 다운로드를 테스트중에 있습니다.
데이터 다운로드중 항상 일정 양의 데이터를(1~2Kbyte) 남기고 소켓이 SOCK_CLOSE_WAIT 되어 데이터 전부를 받아오지 못하는 현상이 발생합니다.
설정쪽에 문제인거 같은데 어디부분을 확인하면 될까요?
도움부탁드립니다.
//test code
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdbool.h>
#include <time.h>
#include "stm32f4xx_hal.h"
#include "HAL_Config.h"
#include "W5x00RelFunctions.h"
#include "MQTTClient.h"
#include "dns.h"
#include "wizchip_conf.h"
#include "socket.h"
#include "httpClient.h"
#include "w5500_control.h"
#include "lib_stdxx.h"
#include "m95m02_hal_spi.h"
#include "key.h"
#include "common.h"
#include "user_conf.h"
#include "dhcp.h"
#include "SSLInterface.h"
void log_net(char *log);
void func_pack_http_get_download_header(uint8_t* buff, uint16_t size_buff, uint8_t* srv_ip, uint16_t srv_port, char* interface);
uint8_t func_http_get_download_file(uint8_t sockno, uint8_t* srv_ip, uint16_t srv_port, char* interface, uint16_t timeout_ms, uint8_t* buff, uint16_t size_buff);
uint8_t func_analysis_http_download_header(uint8_t* buffer, uint16_t len_buf, uint8_t *resp_code, uint8_t *is_stream, uint32_t *cont_len);
uint8_t buf[2048];
int httpclient_get_test(void)
    //FIXME input your server ip to download file
    uint8_t srv_ip[] = {192, 168, 1, 2};
    uint16_t srv_port = 8000;
    setRTR(5000);
    setRCR(3);
    // HAL_Delay(100);
    //DHCP
    // for(;func_dhcp_get_ip_sub_gw(1, mac, &dhcp_get, 500) != 0;);
    // if(func_dhcp_get_ip_sub_gw(1, mac, &dhcp_get, 500) == 0)
    //  setSUBR(dhcp_get.sub);
    //  setGAR(dhcp_get.gw);
    //  setSIPR(dhcp_get.lip);
    //  close(1);
    //  log_net("0");
    memset(buf, 0 , sizeof(buf));
    func_http_get_download_file(1, srv_ip, srv_port, "/4096.bin", 10000, buf, sizeof(buf));
    for(;;)
//      func_led1_toggle();
        HAL_Delay(500);
    uint16_t local_port = 60000, len = 0, cnt = 0;
    uint8_t sendok = 0, recv_start = 0;
    uint8_t cache[2048];
    uint16_t cache_cont_len;
    uint32_t cont_len, download_cont_len;
    func_pack_http_get_download_header(buff, size_buff, srv_ip, srv_port, interface);
//  setkeepalive(sockno);//auto
    IINCHIP_WRITE(Sn_KPALVTR(sockno),0x00);//manual
    memset(cache, 0 , sizeof(cache));
    cache_cont_len = 0;
    for(;;)
        switch(getSn_SR(sockno))
            case SOCK_INIT:
                    connect(sockno, srv_ip, srv_port);
            break;
            case SOCK_ESTABLISHED:
                if(sendok == 0)
                    log_net("1");
                    len = strlen((char *)buff);
                    send(sockno, buff, len);
                    sendok ++;
                    if(getSn_IR(sockno) & Sn_IR_CON)
                        setSn_IR(sockno, Sn_IR_CON);
                        break;
                len = getSn_RX_RSR(sockno);
                if(len > 0)
                    cnt = 0;
                    memset(buff, 0, size_buff);
                    len = recv(sockno, buff, len);
                    if(recv_start == 0)
                        uint8_t res, resp_code, isstream;
                        log_net("2");
                        if(cache_cont_len + len <= sizeof(cache))
                            log_net("3");
                            memcpy(cache+cache_cont_len, buff, len);
                            cache_cont_len += len;
                            len = 0;
                        else
                            uint32_t len_copy;
                            log_net("4");
                            len_copy = sizeof(cache) - cache_cont_len;
                            memcpy(cache+cache_cont_len, buff, len_copy);
                            memcpy(buff, buff + len_copy, len - len_copy);
                            memset(buff + (len - len_copy), 0, size_buff - (len - len_copy));
                            len = len - len_copy;
                            cache_cont_len = sizeof(cache);
                        res = func_analysis_http_download_header(cache, cache_cont_len, &resp_code, &isstream, &cont_len);
                        if(res == 0)
                            if(resp_code != 200 || isstream != 1)//response code 200, must be iostream
                                log_net("22");
                                return 3;// response not ok
                            recv_start++;
                            //logic -> file size should be no more than 108 Kbytes
                            if(cont_len > 108*1024)
                                log_net("23");
                                return 4;
                            //if download file done
                                uint32_t tmp_len;
                                uint8_t* pos_header;
                                pos_header = (uint8_t*)strstr((char*)cache, "\r\n\r\n");
                                //remove header, save file byte to cache
                                tmp_len = cache_cont_len - (pos_header + 4 - cache);
                                memcpy(cache, pos_header + 4, tmp_len);
                                memset(cache + tmp_len, 0 , sizeof(cache) - tmp_len);
                                cache_cont_len = tmp_len;
                                download_cont_len = cache_cont_len;
                                if(len > 0)
                                        log_net("5");
                                        download_cont_len += len;
                                        len = 0;
                                    else
                                        uint32_t len_copy;
                                        log_net("6");
                                        //TODO write to FLASH backup
                                        memset(cache, 0, cache_cont_len);
                                        cache_cont_len = 0;
                                        cache_cont_len = len;
                                        download_cont_len = sizeof(cache) + cache_cont_len;
                                if(download_cont_len == cont_len)// small file download done
                                    log_net("7");
                                    //TODO write to FLASH backup and record
                                    disconnect(sockno);
                                    return 0;//download file done
                    else
                        IINCHIP_WRITE(Sn_CR(sockno),Sn_CR_SEND_KEEP);//keep-alive manual
                        //file size is big, write to FALSH several times
                            log_net("8");
                            len = 0;
                        else
                            uint32_t len_copy;
                            log_net("9");
                            // func_usart2_dma_send_bytes(cache, cache_cont_len);
                            cache_cont_len = 0;
                        //if donwload file done
                            log_net("10");
                            disconnect(sockno);
            break;
            case SOCK_CLOSE_WAIT:
                    close(sockno);
                    log_net("21");
                    return 2;//read timeout
            case SOCK_CLOSED:
                    close(sockno);
                    sendok = 0;
                    recv_start = 0;
                    if(local_port > 65400)
                        local_port = 60000;
                    socket(sockno, Sn_MR_TCP, local_port++, Sn_MR_ND);
            break;
        cnt ++;
        if(cnt >= timeout_ms)
            log_net("20");
            return 1;//connect timeout
        HAL_Delay(1);
    *resp_code = 0;
    *is_stream = 0;
    *cont_len = 0;
    if(strstr((char*)buffer, "\r\n\r\n") != NULL)//response header ok
        char *p1, *p2;
        p1 = strstr((char*)buffer, "HTTP/1.1 200");
        if(p1 != NULL)// io stream
            *resp_code = 200;
        p1 = strstr((char*)buffer, "Accept-Ranges: bytes");
            *is_stream = 1;
        p1 = strstr((char*)buffer, "Content-Length: ");
        if(p1 != NULL)
            p2 = strstr(p1, "\r\n");
            if(p2 != NULL)
                char str_len[8] = {0,};
                memcpy(str_len, p1 + strlen("Content-Length: "), p2 - p1 - strlen("Content-Length: "));
                *cont_len = atoi(str_len);
                return 0;
    return 1;
    // uint8_t logsrv_ip[] = {192, 168, 1, 105};
    // socket(2, Sn_MR_UDP, 7890, 0x00);
    // sendto(2, (uint8_t*)log, strlen(log), logsrv_ip, 9876);
    DEBUG_PRINTF("%s\r\n", log);
    uint8_t tmp[64];
    //header
    memcpy(buff, "GET ", strlen("GET "));
    strcat((char *)buff, interface);
    strcat((char *)buff, " HTTP/1.1\r\n");
    memset(tmp, 0 , sizeof(tmp));
    sprintf((char*)tmp, "Host: %d.%d.%d.%d:%d\r\n", srv_ip[0], srv_ip[1], srv_ip[2], srv_ip[3], srv_port);
    strcat((char *)buff, (char*)tmp);
    strcat((char *)buff, "Connection: Keep-Alive\r\n");
    strcat((char *)buff, "User-Agent: W5500\r\n");
    strcat((char *)buff, "Accept-Encoding: gzip,deflate\r\n");
    strcat((char *)buff, "\r\n");
CLOSE WAIT 상태는 Peer로부터 FIN Packet을 수신한 상태입니다.
Peer에서 FIN Packet을 전송한 이유를 찾아야할것 같습니다.
추가로 CLOSE WAIT 상태에서도 데이터 송수신이가능합니다.
CLOSE WAIT 상태에서 close 명령어를 내리지않고 데이터 수신을 마저 한 후 에 close 되도록 하는것도 방법이 될 것 같습니다.
