Question on FCS
Using a W5100s in MACRAW mode, what happens when a packet is received with a bad frame check sequence? Is it rejected, and if so, is there any way to tell that a packet has been rejected? While I’m on the subject, does the W5100s append a FCS when it puts the packet out?
