recv Function in socket.c
While looking through the recv function I see what looks like a bug that I haven’t been able to track down online. Here’s the code in question.
        while (1)
            recvsize = getSn_RX_RSR(sn);
            tmp = getSn_SR(sn);
            if (tmp != SOCK_ESTABLISHED)
                if (tmp == SOCK_CLOSE_WAIT)
                    if (recvsize != 0)
                        break;
                    else if (getSn_TX_FSR(sn) == getSn_TxMAX(sn))
                        close(sn);
                        return SOCKERR_SOCKSTATUS;
                else
                    close(sn);
            if ((sock_io_mode & (1 << sn)) && (recvsize == 0)) return SOCK_BUSY;
            if (recvsize != 0) break;
The line: else if (getSn_TX_FSR(sn) == getSn_TxMAX(sn))
is bothering me. Why are we looking at the TX registers rather than the RX registers? I can’t get this to make sense.
Comments welcome!
Just David
When I send an email to WIZnet, they tell me to post my issues here. Well, I’ve done that… Could I get a WIZnet response, please? Pretty please!
hi David,
Chip and MCU communicate. This is the process of double-checking the data sent.
else if (getSn_TX_FSR(sn) == getSn_TxMAX(sn)) is It reads the register value on the chip.
But, why is it checking the TX registers rather than the RX registers? This the recv() function.
Hi @JustDavid
you need to know the upper condition is in “if (tmp == SOCK_CLOSE_WAIT)”.
Socket_closed_wait means socket recved FIN.
So, Socket need to check before close communication the rest of the transmit data in tx buffer.
that is why it check tx stuff in rx recv. :slight_smile:
