Hello, I have probleme getting the rigth data to be transmit. I am using a WIZ750SR-110 to convert RS232 data to Ethernet data. The data on the side of the serial interface are good, but not on the Ethernet side.
This is the data that my serial device send to the serial interface of the WIZ750SR-110.
I try with a second device, but only connect to my pc this time. I connect the Ethernet cable to my PC and with a USB to serial converter I connect the other end to my PC and commuinicate with terminal to transmit data. The problem is still there.
I also try to connect my module as a TCP client, but I was not able to get a TCP connection.
Downgrade the firmware to the 1.2.9 version and no different result so I came back to 1.3.3, but now I have problem to change setting with the config tool. It does not work any more. The setting does not take place.
It will be realy appraciate if someone can help me with my problem.
