Gurom
1
Hi frinds!
I use the GET requests to the server.
I don’t like my code. My code is working but…
If I need to send the GET requests 3 times then I do:
– create socket
– Send GET
– recieve answer
– close socket
– create socket
– Send GET
– recieve answer
– close socket
– create socket
– Send GET
– recieve answer
– close socket
I want to open the socket for many GETs requests. How to do it?
Please see my code in attached file. I indicated the part which must work 1 time only.
louis
2
Hello.
Which product are you using?
Do you want to open multiple sockets?
Thank you. I’ll answer that.
louis
4
What does big q-ty mean?
Do I have to create sockets and send the data?
I’m curious what you’re trying to make it with.
Gurom
5
Hi Louis!
I will explain you shortly.
Now I use algorithm:
Open socket / Send GET / Close socket + Open socket / Send GET / Close socket
I want to use the following algorithm:
Open socket / Send GET + Send GET + Send GET / Close socket
louis
6
I will attach the example of LoopBack.
In the example, there is content SOCKET opens, closes, and sends data.
I think you can modify it according to your algorithm.
Thank you,
Hi Gurom, Can you please provide me the full code?
Thanks
Hi Gurom.
Can you send the full code? Thanks already.
mrkam
9
Hi Gurom. Can you please send the full code?
