dekip
October 31, 2021, 9:17am
1
Can someone help with importing the WizFi360 package into Arduino IDE?
I am following this page: https://wizfi.github.io/Document/docs/basic_guides/arduino_ide
When I try to install WizFi360 in board manager, I get an error downloading … Which indicates that there is no file to download. Any other solution?
austin
November 1, 2021, 12:14am
2
Unfortunately, the Arduino library you mentioned does not support it.
If you want to use the Arduino library, please refer to the link below.
dekip
November 1, 2021, 8:43am
3
But, did it supported earlier? Is this your page? I am not talking about the library, I am talking about the JSON package. Not the same.
Will there be a support for an Arduino IDE? To program this board as a stand-alone device?
The library you mention I haven’t tried, yet.
austin
November 2, 2021, 12:51am
4
Sorry,
Where the JSON packages were supported, support has been stopped.
So, the device alone can not be programmed using Arduino IDE.
dekip
November 2, 2021, 10:38am
5
Pitty…
The support through Arduino IDE would give this platform a huge boost. This way, it is a way unusable.
Can you tell me if there was support, if it worked, why you stopped it?
Is there a plan to start supporting IDE again?
austin
November 3, 2021, 2:20am
6
Where the JSON packages were supported, support has been stopped, so we can no longer support.
Sorry, we don’t have any plans to support WizFi360 to be programmable as an Arduino IDE.
