I’d like to run a simple SPI communication test using the ioLibrary. So far, I can read registers without any issue but cannot write to them for some reason.
Can someone tell me if there is a step that I am missing after writing to a register? Do I need to pull the chip into reset for a moment?
What I’d like to do is the following
Read a register value
Write a new value to that register
Read the new value back
Can someone give me a good register to test this on? Thanks.
Thanks for the feedback. This is a bit more than what I am looking for, however. I wrote a simple program to read a register and write to a register. I want to read a second time to make sure the data is updated.
Can you give me a good register to test this on? I know some bits are write-protected in certain registers.
