Hi, I have a WizFi360-PA configured with some AT commands including setting it as softAP, setting SSID and password. The response for all the configuration commands was OK.
After the configuration commands, the SSID showed up correctly with strong Wi-Fi signal. However when I tried to connect to this SSID, it always says the password is incorrect. I am pretty sure I typed in the correct password and I also tried on different computers. It’s the same issue.
I also tried on another WizFi360-PA and it’s the same issue. So it doesn’t look like it’s related to that particular unit.
With the same configuration command set, I was able to get WizFi360-CON to work. Is there anything different in terms of the firmware between -PA and -CON?
The configuration command set is shown in below for your reference. Thanks!
AT
ATE0
AT+GMR (response is AT version 1.1.1.7. SDK version 3.2.0)
AT+CWMODE_DEF=2
AT+CWSAP_DEF=“WizFi360_7”,“12345678abc”,1,3,4,0
AT+CIPAP_DEF=“192.168.42.1”,“192.168.42.1”,“255.255.255.0”
AT+CWDHCPS_DEF=1,120,“192.168.42.100”,"192.168.42.200
AT+CIPSTO=7200
AT+CIPMUX=1
AT+CIPSERVER=1,8888
