I am looking for the schematics for the WIZ145sr module. I want to know the connections between the WIZ5300 and the CORTEX 3M MCU.
Thanks
Mike Clery
Thruput
Attached is the 145SR hardware schematic.
Hi Louis
I am designing a new product in which I have chosen the WIZ5300 chip. I have chosen this because of its speed. I purchased several WIZ145SR (with the serial board) to investigate performance.
My application is a 24 channel audio to network device. The WIZ145SR uses the W5300 and the has a STM32 Cortex3 MCU. Unfortunately the WIZ145SR only supports serial to network and does not let me access the vast GIO pins available on the STM32 Cortex 3.
I have now purchased a STM32F103ZET6 development board that supports the ST32M Cube family of software tools, and this board has access to all of the STM32 Cortex I/O capability. I have also purchased the WIZ830, which is a WIZ5300 with a RJ45. I have connected the WIZ830 to the STM32 Cortex3 using the same pin connections as on the WIZ145SR.
I would like to load the WIZ145SR firmware into my STM32 development board and use the STM Cube-IDE suite to modify the serial code for my new purpose, but re-using the WIZ145-SR interface to the WIZ5300.
Could you tell me if the source codes are available for the WIZ145SR serial card and what STM32 development tool you used?
Thanks
Mike Clery
Thruput
mike.clery@thruput.co.uk
Hi
Have you an answer for the WIZ145SR module schematic?
Not the the connections between the ARM processor and the serial card but the connections between the W5300 chip and the STM32F103ZET6 ARM MCU. I want to connect a WIZ830MJ module to a STM32F103ZET6 development board so I can still run the WIZ145SR code.
Thanks
