Hello guys
I’m looking for a best schematic for w5500 with POE , i found some schematic but that works for 100 feet distance
Thanks in advance
Hello guys
Thanks in advance
Hello @Eng.kourosh
Sorry for the late reply.
Unfortunately, the W5500 PoE schematic is not officially supported.
Please refer to it.
thanks.
Hello @austin
Thanks for your reply
But theoretically it should work yes?
I have a question about web server too, can you help me
Hi @Eng.kourosh
It is possible if the PoE circuit is implemented.
I can help you with anything simple.
And there is a web server example used as W5500.
Please refer to the link below.
Hello @austin
Thank you
I need simple for web server which is we could send http command to it and control relay
Is there any simple for that?
Hi @Eng.kourosh
If you are looking for a simpler example than the wiz550web example, which is the link shared above,
I don’t know if this will help, but please refer to the link below.
Hello @austin
Thanks
I tested it before but it just work from web UI it doesn’t work when we wanna send http command and turn on relay like this url:
I know it need to develop but i need some docs to guiding me how can i do that with io library
Hi @Eng.kourosh
For additional functions except examples, you have to implement them yourself.
Sorry for not being of any help.
Hello @austin
Your library is work for http get method right?
For my purpose (http command) need to post method right?
Hi @Eng.kourosh
Are you talking about the ‘ioLibrary_Driver’?
‘ioLibrary_Driver’ Support several HTTP methods.
Please refer to the ‘parse_http_request()’ function in ‘ioLibrary_Driver/Internet/httpServer/httpParser.c’.
Hello @austin
Thanks
Yes i used this library that your colleague sent it to me:
Is this library help me for http command ?
If yes please help me to how can i use functions for this purpose
Hi @Eng.kourosh
It is an example of implementing a simple HTTP server,
I think it will be useful as a reference for implementing the HTTP server.
Hi @Eng.kourosh
The library can be used for your purpose.
However, the necessary parts must be further implemented.
Hello @austin
Thank you so much
Is there any ducment for helping me for that?
how can i read web index (like : 192.168.100.100/text)
For example the text after ip address should be analyze to get data from user when they enter the http command
Which function should i use?
I wish there is a sample code
