Hello.
While implementing mcu and tcp/ip client communication with w5500-based Ethernet shield, there was a problem that the chip version could not be read properly.
Look at the w5500 datasheet, it is normal to get 0x04 as the version value, but I get 0x00
But the board is assigned an ip.
If I give the command ping 192.168.0.75 in cmd it will respond.
Also, communication programs such as Hercules or Easytum cannot be used to connect.
The io library is using version 1.0.2, and it has been confirmed that there is no problem with the hardware connection.
Which part is the problem?
And… Unfortunately, I don’t have an oscilloscope…
Below are the hardware specifications. The code is also attached.
Ethernet shield: https://www.devicemart.co.kr/goods/view?no=34412
mcu: NUCLEO-F411RE | Mbed
If there is a Korean developer, please reply in Korean…
Also, since this is my first time using the forum, please understand that I have edited the post several times.
main.c
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "spi.h"
#include "usart.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include <stdio.h>
#include <string.h>
#include "stm32f4xx_hal.h"
#include "loopback.h"
#include "wiz_init.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
wiz_NetInfo gWIZNETINFO = {.mac = {0xA8, 0x61, 0x0A, 0xAE, 0x6F, 0xB6},
.ip = {192, 168, 0, 75},
.sn = {255, 255, 255, 0},
.gw = {192, 168, 0, 1},
.dns = {0, 0, 0, 0},
.dhcp = NETINFO_STATIC};
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
uint8_t eth0_buf[512];
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
uint8_t ret, NetValue;
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_USART2_UART_Init();
MX_SPI1_Init();
/* USER CODE BEGIN 2 */
W5500HardwareReset();
NetValue = wizSystemInit();
wizchip_setnetinfo(&gWIZNETINFO);
print_network_information();
if(NetValue == 1)
printf("\r\nNetwork_Info_Setting_Complete\r\n");
else
while(1)
printf("Network_Setting_ERROR!!\r\n");
HAL_Delay(1000);
if(getVERSIONR() != 0x04)
printf("[%d]VERSION ERROR!!\r\n",getVERSIONR());
else
printf("[%d]VERSION CORRECT\r\n",getVERSIONR());
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
ret = loopback_tcps(0, eth0_buf, 11000);
/*if(eth0_buf[0] != 0 )
printf("ret = %d, buf = %X[%s]\r\n", ret, eth0_buf[0],eth0_buf);
if(eth0_buf[0] == 0x5a)
printf("data = 0x5a \r\n");
eth0_buf[0] = 0xA5;
ret = send(0, eth0_buf, 1);
else
ret = send(0, eth0_buf, strlen(eth0_buf));
memset(eth0_buf, 0, sizeof(eth0_buf));
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 16;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
RCC_OscInitStruct.PLL.PLLQ = 4;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN 4 */
#pragma GCC push_options
#pragma GCC optimize ("O0")
void delayUS(uint32_t us)
//volatile uint32_t counter = 12*us;
volatile uint32_t counter = 2*us;
while(counter--);
#pragma GCC pop_options
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
wiz_init.c
#include "usart.h"
#include "spi.h"
int wizSystemInit(void)
int8_t tmp;
uint8_t memsize[2][8] = {{2,2,2,2,2,2,2,2},{2,2,2,2,2,2,2,2}};
W5500DeSelect();
HAL_Delay(10);
reg_wizchip_cs_cbfunc(W5500Select, W5500DeSelect);
reg_wizchip_spi_cbfunc(W5500ReadByte, W5500WriteByte);
//reg_wizchip_spiburst_cbfunc(W5500ReadBurst, W5500WriteBurst);
printf("W5500 initialized fail.\r\n");
return -1;
printf("Unknown PHY Link status.\r\n");
return -1;
return 1;
void W5500HardwareReset(void)
HAL_GPIO_WritePin(W5500_RESET_Port ,W5500_RESET_Pin,GPIO_PIN_RESET);
delayUS(500);
HAL_GPIO_WritePin(W5500_RESET_Port, W5500_RESET_Pin,GPIO_PIN_SET);
void W5500WriteByte(uint8_t txByte)
uint8_t rtnByte;
W5500Select();
while (HAL_SPI_GetState(&hspi1) != HAL_SPI_STATE_READY);
HAL_SPI_TransmitReceive(&hspi1,&txByte,&rtnByte,1,10);
unsigned char W5500ReadByte(void)
uint8_t txByte = 0xFF;
uint8_t rtnByte = 0;
W5500Select();
return rtnByte;
void W5500WriteBurst(uint8_t* pBuf, uint16_t len)
HAL_GPIO_WritePin(SPI1_CS_GPIO_Port, SPI1_CS_Pin, GPIO_PIN_RESET);
HAL_SPI_Transmit_DMA(&hspi1, pBuf, len);
void W5500ReadBurst(uint8_t* pBuf, uint16_t len)
uint8_t dataout=0xAA;
HAL_SPI_TransmitReceive_DMA(&hspi1, &dataout, pBuf, len);
void W5500Select(void)
void W5500DeSelect(void)
HAL_Delay(10);
HAL_GPIO_WritePin(SPI1_CS_GPIO_Port, SPI1_CS_Pin, GPIO_PIN_SET);
void Critical_enter(void)
__disable_irq();
void Critical_exit(void)
__enable_irq();
int isLinked(void)
return(getPHYCFGR() & PHYCFGR_LNK_ON);
void print_network_information(void)
printf("\r\n==============Net Info==============\r\n");
printf("Mac address: %02x:%02x:%02x:%02x:%02x:%02x\n\r",gWIZNETINFO.mac[0],gWIZNETINFO.mac[1],gWIZNETINFO.mac[2],gWIZNETINFO.mac[3],gWIZNETINFO.mac[4],gWIZNETINFO.mac[5]);
printf("IP address : %d.%d.%d.%d\n\r",gWIZNETINFO.ip[0],gWIZNETINFO.ip[1],gWIZNETINFO.ip[2],gWIZNETINFO.ip[3]);
printf("SM Mask : %d.%d.%d.%d\n\r",gWIZNETINFO.sn[0],gWIZNETINFO.sn[1],gWIZNETINFO.sn[2],gWIZNETINFO.sn[3]);
printf("Gate way : %d.%d.%d.%d\n\r",gWIZNETINFO.gw[0],gWIZNETINFO.gw[1],gWIZNETINFO.gw[2],gWIZNETINFO.gw[3]);
printf("DNS Server : %d.%d.%d.%d\n\r",gWIZNETINFO.dns[0],gWIZNETINFO.dns[1],gWIZNETINFO.dns[2],gWIZNETINFO.dns[3]);
printf("==============Net Info==============\r\n");
spi.c
#include "spi.h"
#include <stdio.h>
#include <string.h>
#include "socket.h"
#include "wizchip_conf.h"
SPI_HandleTypeDef hspi1;
/* SPI1 init function */
void MX_SPI1_Init(void)
/* USER CODE BEGIN SPI1_Init 0 */
/* USER CODE END SPI1_Init 0 */
/* USER CODE BEGIN SPI1_Init 1 */
/* USER CODE END SPI1_Init 1 */
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SPI1_Init 2 */
/* USER CODE END SPI1_Init 2 */
void HAL_SPI_MspInit(SPI_HandleTypeDef* spiHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(spiHandle->Instance==SPI1)
/* USER CODE BEGIN SPI1_MspInit 0 */
/* USER CODE END SPI1_MspInit 0 */
/* SPI1 clock enable */
__HAL_RCC_SPI1_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**SPI1 GPIO Configuration
PA5 ------> SPI1_SCK
PA6 ------> SPI1_MISO
PA7 ------> SPI1_MOSI
GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF5_SPI1;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* SPI1 interrupt Init */
HAL_NVIC_SetPriority(SPI1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(SPI1_IRQn);
/* USER CODE BEGIN SPI1_MspInit 1 */
/* USER CODE END SPI1_MspInit 1 */
void HAL_SPI_MspDeInit(SPI_HandleTypeDef* spiHandle)
/* USER CODE BEGIN SPI1_MspDeInit 0 */
/* USER CODE END SPI1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_SPI1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7);
/* SPI1 interrupt Deinit */
HAL_NVIC_DisableIRQ(SPI1_IRQn);
/* USER CODE BEGIN SPI1_MspDeInit 1 */
/* USER CODE END SPI1_MspDeInit 1 */
void HAL_SPI_TxRxCpltCallback(SPI_HandleTypeDef *hspi)
if(hspi->Instance == SPI1)
W5500DeSelect();
printf("Data Receive\r\n");
void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
W5500DeSelect();
printf("Data Transmit\r\n");
