I am trying to establish a network with 2 of these modules. I have them on evaluation boards.
I need to be able to exchange serial data between them in udp mode, where one is a udp server and the other is a udp client. They will be connecting to each other only, and not to an existing wifi network.
I am only able to communicate with them using AT commands using a usb cable.
I have tried following the examples in the data sheet, but have not found a way to set up the network.
I usually get [ERROR: WiFi Status] to the AT commands I have used.
I am quite happy to work through the data sheet and work out the details, but I dont know what the basic steps are.
If I want to send data from the client to the server using the AT+SSEND command how do I use it ?
The definition on page 15 of the programmers guide is different to the example on page 72.
Is the timeout necessary ?
Is a character required before the text data ?
Please could you post an example of the AT+SSEND command that will work in this example. I am confused.
