Please. How to load firmware into WIZ850io module?
Wiz850io and Wiz550io not include the MCU.
In my opinion, it would be better to think of it as a sensor module that provides an SPI interface.
Hi, the question was based on information:
Product Description
WIZ850io is an compact size network module that includes a W5500 (TCP/IP hardwired chip with embedded PHY) a transformer and RJ45. The module is designed to be a fully pin-compatible replacement of the WIZ820io which has been widely used in the market over the last few years. The WIZ850io has a very small form factor and is just a little bigger than a usual RJ45 connector. The connection from the WIZ850io to your microcontroller is done by SPI mode 0 & 3. Already existing projects with the WIZ820io can be transformed to be used with the WIZ850io by modifing the firmware.
That is, unless it is intended by modifying the project firmware.
