I am using WiZFi 360 in TCP server Mode and WiZFi 360 is having firmware version 1.0.7.5.
In this version, i see that Transparent Mode is not supported in TCP Server configuration.
So, i wanted to confirm that whether Transparent Mode supported in TCP Server Configuration or not ?
As the server mode does not support Transparent data transmission, i am using AT+CIPSENDBUF CMD for transmitting data into network(TCP Client will receive this data on other end)
Transmitting data in below sequence
AT+CIPSENDBUF=0,866
Send 866 bytes (using UART comm interface to WiFi Module)
Delay of 23ms
Repeat 1, 2,3 steps upto 10 min continuously
When i am testing the above changes, observed busy p… and sometimes busy s… as shown below.
In below snippet, 22222222222…are the actual data that i am transmitting.
When busy p… is occurred, AT+CIPSENDBUF this CMD itself is transmitted to network (observed this CMD on TCP Client )
So, my questions are
When is this busy p… and busy s… occurs ? (on my testing, i randomly observed this but any input on your end is very much appreciated)
When busy p… occurs, what should be the handling on user end, means does user need to wait for some time and then send next SENDBUF CMD ? If yes, what should be the wait time ?
Some times, i observed SEND FAIL when using above 3 steps in loop. So what is the root cause of this SEND FAIL and how should user handles this ?
busy s… : Busy sending. Can’t respond to new input because it is sending previous input.
busy p… : Busy processing. Can’t respond to new input because it is processing previous input.
Next AT command must be entered after the response result of the AT command, such as ‘OK’ or ‘ERROR’.
When data transmission fails, ‘SEND FAIL’ message is output.
After sending data, when ‘SEND OK’ message is output, send next data.
