We are using WizFi 360 WiFi module with firmware version 1.0.7.5.
Configured WiFi module as a TCP Server.
I tried to set the TCP Server Timeout using AT+CIPSTO CMD, always received ERROR as a response from WizFi module. Query CMD (AT+CIPSTO? ) is working fine but Set CMD is not working (see the below attached screenshot)
Can you please help us with correct way of using TCP server Timeout CMD and the reason for getting ERROR even though the format of using CMD is correct?
Thanks,
Padmini
