I wonder why interrupts comes from another socket and set IR register
Interrupts init
socket_0_config.sn = 0 //structure of socket settings
setIMR (0x00); // Not use Wizchip IR
if (getIMR()!=0x00) UART_Printf(“\nERROR: IMR set”); //check seted val
setSIMR (1<<socket_0_config.sn);// Socket 0 Enable
if (getSIMR()!=0x01) UART_Printf(“\nERROR: SMIR set”);
setSn_IMR(socket_0_config.sn,0x1F); //Enable all socket interrupts
if (getSn_IMR(socket_0_config.sn)!=0x1F) UART_Printf(“\nERROR: Sn_IMR set”);
// Interrupt function
// UART_Printf - debug
void ETH_interrupt (void)
socket_0_config.uSIR.IR_reg = getSn_IR(socket_0_config.sn); //read socket interrupt reg
socket_0_config.uWIZ_IR.WIZ_IR_reg = wizchip_getinterruptmask(); //getIR(); read chip int. reg
//–debug
UART_Printf(“\n----> IR: 0x%02X <----\n”,getIR());
UART_Printf(“\n----> SIR: 0x%02X <----\n”,getSIR());
UART_Printf(“\n----> Sn_IR: 0x%02X <----\n”,getSn_IR(socket_0_config.sn));
UART_Printf ("\n0x%02X MP:%d,PPPoE:%d, Un:%d, Conf:%d\n",
socket_0_config.uWIZ_IR.WIZ_IR_reg,
socket_0_config.uWIZ_IR.WIZ_IR_Flags.IR_MPack,
socket_0_config.uWIZ_IR.WIZ_IR_Flags.IR_PPPoEConClose,
socket_0_config.uWIZ_IR.WIZ_IR_Flags.IR_DestUnreach ,
socket_0_config.uWIZ_IR.WIZ_IR_Flags.IR_IPConflict);
socket_0_config.uSIR.IR_reg = 0; //cl reg
socket_0_config.uWIZ_IR.WIZ_IR_reg = 0; //clr
setSn_IR(socket_0_config.sn,0x1F); //ACK socket interrupts and clear int
setIR(0xF0);//ACK chip interrupts and clear int
Printf return at terminal
This is interrupt generated when I send data from chip to PC.
—> IR: 0x20 <----
----> SIR: 0x20 <----
----> Sn_IR: 0x00 <----
0x20 MP:0,PPPoE:1, Un:0, Conf:0
As you can see the wizchip interrupt PPPoE is generated. I don’t know why (It is blocked). I expect Sn_IR SEND_OK int.
Thanks for support
Krzysztof
Edit. This behaviour only occurs when I set SEND_OK interrupt mask in Sn_IMR
setSn_IMR(socket_0_config.sn,(SIK_SENT))
