In regards to the WIZ750SR-485 without the Eval board
When I go into serial command mode by sending the “+++” on the 422 RXD+(J1-3) and 422 RXD- (J1-5)input. I can also send an “LI” command, but the response comes out on the 422 TXD+ (J1-7) and 422 TXD- (J1-9) output
My question, is there any way I can switch over the 485Mode, where both the RXD and TXD response come out a single port in serial command mode?
In normal GW mode, RS485 works just fine, but not in serial command mode
Any help greatly appreciated
