Hello.
I try to make a Modbus RTU to Modbus TCP gateway out of a WIZ750SR-RS485.
For that I downloaded the Source Code from Github (GitHub - Wiznet/WIZ750SR: WIZnet Serial to Ethernet(S2E) module based on W7500 chip, WIZ107/108SR S2E compatible device).
Unfortunately the project is to big to use the free Keil version, so I have tried to port the code to Eclipse. I spent a lot of hours until now, but I can’t get the code running. It compiles fine after a lot of fiddling around. The binary is much bigger (~100k) than the original and the controller won’t run with it. I’m now at the point where I don’t know what I should try next. Could someone have a look at the Elcipse project or have a working one for me, please? Or for any other free to use IDE? To modify the original code to my Modebus needs should then be easy for me.
Thanks a lot,
Christian
WIZ750SR.zip (529,8 KB)
