void loopback_tcps(u_char ch /**< channel(socket) index */ )
//u_char * data_buf = (u_char*) TX_BUF; // 0x1100, RX_BUF = TX_BUF+TX_RX_MAX_BUF_SIZE
switch (getSn_SR(ch))
case SOCK_ESTABLISHED: /* if connection is established */
if(bchannel_start[ch]==1)
bchannel_start[ch] = 2;
if ((len = getSn_RX_RSR(ch)) > 0) /* check Rx data */
if (len > max_bufsize) len = max_bufsize; /* if Rx data size is lager than TX_RX_MAX_BUF_SIZE */
/* the data size to read is MAX_BUF_SIZE. */
len = recv(ch, data_buf, len); /* read the received data */
TEST = len;
send(ch, data_buf, len); /* send the received data */
//send_data_processing(0, data_buf, len);
break;
case SOCK_CLOSE_WAIT: /* If the client request to close */
disconnect(ch);
bchannel_start[ch] = 0;
break;
case SOCK_CLOSED: /* if a socket is closed */
if(!bchannel_start[ch])
bchannel_start[ch] = 1;
if(socket(ch,Sn_MR_TCP,4500,0x00) == 0) /* reinitialize the socket */
else listen(ch);
break;
This means that at the time when packet arrives W5100S is having related socket closed, or in any other state not accepting the data from the remote host.
Connection is being established in packets 4-6, then client sends 1 character to the server (W5100S) in packet 11, it does not receive ACK, and performs keep-alive. At the time when keep-alive packet is received, socket is closed.
Why it is closed - dig into your code or put diagnostic output to see how program works and the transition of the socket state.
Let’s look at the Wireshark log:
4 - client sends SYN packet to server (W5100S)
5 - server (W5100S) replies with SYN/ACK to the client, confirming it has got SYN packet
6 - client informs server (W5100S) that it has got SYN reply packet, and from now on connection is established.
11 - client sends single character to the server with push flag set, I guess this is ‘8’ which we see in the picture.
Then server does not reply with ACK packet to this ‘8’ being sent. In packet 23 client again sends one character to the server (same seq=1 ack=1 and len=1), and server replies with RST for this seq=1 and ack=1. I have no explanation why wireshark says “tcp keep-alive”, must look into the packet structure/data to see what it is about.
Therefore something wrong is happening in the server after it has connection established. Why S5100S does not reply with ACK to the packet 11 in the first place - also a good question.
Also your picture shows “connection refused by remote host”, but in wireshark log you attached connection went well, the problem happened on the data transfer.
As I said before - put diag output into your code to see how it flows, and log several connection attempts using wireshark to see several logs and probably getting the idea using more data that just one log.
Connect W5100S to your hercules PC directly. This will eliminate issues which may happen in the routing equipment. I do not say problem is there, but it seems packets are simply being lost in the wireshark output.
W5100S는 hercules PC와 직접 연결하여 테스트 하고 있습니다. wireshark값을 비교하였고 [ACK]라고 수신까지 받았습니다.
하지만 이것이 프로그램 함수를 제거하니깐 정상적으로 동작되는것? 같아요
recv함수 없이 제가 수신된 값을 읽을 수 있는 방법이 있나요?
uint16 recv(
SOCKET s, /< socket index */
uint8 * buf, /< a pointer to copy the data to be received */
uint16 len /**< the data size to be read */
uint16 ret=0; #ifdefDEF_IINCHIP_DBG
printf(“recv()\r\n”); #endif
if ( len > 0 )
//recv_data_processing(s, buf, len);
IINCHIP_WRITE(Sn_CR(s),Sn_CR_RECV);
/* +20071122[chungs]:wait to process the command... */
while( IINCHIP_READ(Sn_CR(s)) )
ret = len;
return ret;
rece함수 내부의 recv_data_processing(s, buf, len);을 주석처리하니깐 RST,ACK가 발생하지 않습니다.
This is very good finding! If you look at the wireshark output, you see that window size decreases - to 2047 from 2048 when it received one char, and then to 2037 when it receives another 10 chars. And Ack is being advanced accordingly. This is because you commented the receive action and W5100S is having its RX buffer filled.
Now the main question - why calling this function recv_data_processing causes the issue? In my opinion, the first thing I would look at (not in your posted code) is value of len. How do you obtain it? May it have invalid, wrong value?
To understand the meaning and how code works please refer to the datasheet chapter 4. The code you commented just gets data through the boundary of the socket buffer. The RX pointers must have been managed in the wiz_read_buf() call. What I would do in this situation - display and verify all the values all the functions being called return, and check against register descriptions in datasheet to ensure there’s no misconfiguration and values are correct.
