[WIZ550web]
WIZ550web 모듈 + evb 보드 로 웹페이지에서 제어를 하다보면
HIGH Density Flash memory
WIZnet WIZ550web Revision 1.1
Embedded Web Server Module
Firmware Version 2.0.0
Device Name : WIZ550WEB
MAC: 00:08:DC:69:44:65
IP: 192.168.77.100
GW: 192.168.77.1
SN: 255.255.255.0
DNS: 8.8.8.8
Storage mount succeed
Type : sFlash
Available Memory Size : 973 kB / 973 kB ( 0 kB is used )
Type : SDHC
Available Memory Size : 7753312 kB / 7753728 kB ( 416 kB is used )
########## SW1 and SW2 were pressed.
########## Data flash flag was cleared.
########## Please reset a target.
GLOBAL EEPROM DATA ERASE…
ERASE DONE
ERASE DONE
########## Factory Test is started.
########## A0 = 2021 || A1 = 2201 || A2 = 2021 || A3 = 2180
########## RS422 TX:TEST
########## SW2 Released OK.
########## SW2 Pressed OK.
########## SW3 Released OK.
########## SW3 Pressed OK.
이런식의 에러가 나면서 mac address 가 변경 되어 버리는 경우가 발생 합니다.
원인을 학인 할수 없어서 문의 합니다.
