Dear Wiznet Support Team,
we’ve started to implement a webserver using the Wiz820io Modul.
The web server provides a small page which is requested automatically by the browser every second.
The module closes the connetion after transmitting the web page and the browser opens the connection again.
This works quite well, but after a certain time (3-10 minutes) the request of the browser won’t be accepted by the module anymore.
If we then debug the programm we noticed, that during “re-open” of the socket, when we have to write to mode register (SnMR = 0x1 for TCP), it doesn’t hold it’s value.
uint8 socket(SOCKET s, uint8 protocol, uint16 port, uint8 flag)
uint8 ret;
#ifdef DEF_IINCHIP_DBG
printf(“socket()\r\n”);
#endif
if ((protocol == Sn_MR_TCP) || (protocol == Sn_MR_UDP) || (protocol == Sn_MR_IPRAW) || (protocol == Sn_MR_MACRAW) || (protocol == Sn_MR_PPPOE))
close(s);
[color=#FF0000]IINCHIP_WRITE(Sn_MR(s),protocol | flag);[/color]
[color=#FF0000]// reading back SnMR here returns 0 [/color]
if (port != 0) {
IINCHIP_WRITE(Sn_PORT0(s),(uint8)((port & 0xff00) >> 8));
IINCHIP_WRITE((Sn_PORT0(s) + 1),(uint8)(port & 0x00ff));
} else {
local_port++; // if don't set the source port, set local_port number.
IINCHIP_WRITE(Sn_PORT0(s),(uint8)((local_port & 0xff00) >> 8));
IINCHIP_WRITE((Sn_PORT0(s) + 1),(uint8)(local_port & 0x00ff));
IINCHIP_WRITE(Sn_CR(s),Sn_CR_OPEN); // run sockinit Sn_CR
/* wait to process the command... */
while( IINCHIP_READ(Sn_CR(s)) )
ret = 1;
else
ret = 0;
printf(“Sn_SR = %.2x , Protocol = %.2x\r\n”, IINCHIP_READ(Sn_SR(s)), IINCHIP_READ(Sn_MR(s)));
#endif
return ret;
That means if we read back the SnMR we get 0x0 instead of 0x1.
We checked the SPI address and data values with the oscilloscope everthing is OK and indeed the module returns 0 instead the 0x1 we’ve wrote before to the register.
Do you have any idea according to the reasons of this behaviour?
Thanks a lot!
Best regards
Ralph
