I have completely activate the SPI communication. I can read and write data to W5500 chip. I checked from scope and from keil.
I am going to use this chip for tcp communication. My master is a Freescale KL25 MCU and w5500 is my slave.
I have found the tcp guide for w5500.
For now I am just using socket 0.
I have written the gateway, source IP and read them. They are ok.I can read them.
then for tcp:
1- I adjusted the mode register for TCP usage.( 0x01) (I read this value correctly)
2-I adjusted port adress as 31000 (I read this value correctly)
3- Command register, SN_CR= 0x01 (Open the port)
the problem starts here. I should read 0x13(SOCK_INIT) from the status register. However I cannot read that value.
Then I will have w5500 to go listen mode.
Could you please help me what should I do. Is there anything I should do write or check ?
I think that the control byte maybe wrong and you did accesse the other device as memory, instead of W5500.
As you mentioned before,
If the socket registers as Sn_MR, Sn_SPORT is normally write & read, OPEN command in Sn_CR regsiter will change the Sn_CR from SOCK_CLOSED to SOCK_INIT.
Plz, Verify block selected bits in the control byte.
Thank you.[/quote]
I have already checked these BSBs. I think there is no problem of SPI frame. Because I can read and write.
For example RTR(retry time register) has default of “0x07D0” which I can read and write via SPI.
If you have no problem about spi accessing, try to open all SOCKET with Sn_CR.
If all socket can’t not be opened, check the reset time of W5500.
I have solved the problem. The problem was related with my spi_send function.
I arranged again and with the correct addres values.
Thanks for all replies.
hi,
my Sn_SR register value always set 0x00, its not change its value from 0x00 to 0x22.
my code:
START:
setMR(Sn_MR_UDP);
setSn_PORT(0, 11000);
setSn_CR(0, Sn_CR_OPEN);
if(getSn_SR(0) !=SOCK_UDP)
setSn_CR(0, Sn_CR_CLOSE);
goto START;
