I am having an issue that I don’t understand. I believe it is causing some problems with a particular website. I sent a packet with “ESTABLISHED” connection (Sn_SR = 0x17). I then receive and interrupt for the socket I used to send the packet. The Sn_IR registers shows 0x18 when I read it in the interrupt service routine. It looks like there was a SEND_OK but how can there be a TIMEOUT bit set also? The next time I sent a packet to the website, the Sn_SR is 0x00 (CLOSED). I think this is causing some issue because there is no response to the TCP SYN packet that was sent.
I don’t understand how an established connection can just timeout especially since the packet got sent.
