The client runs.
int32_t WIZNET_Run(uint8_t sn, uint8_t* buf, uint8_t* destip, uint16_t destport, uint16_t *rcv_size)
int32_t loc_ret, ret = 0; // return value for SOCK_ERRORs
uint16_t size = 0, sentsize=0;
static int first_send = 0;
// Port number for TCP client (will be increased)
static uint16_t any_port = 50000;
uint8_t status = wiz_getSn_SR(sn);
switch(status)
case SOCK_ESTABLISHED :
if(status & Sn_IR_CON)
wiz_setSn_IR(sn, Sn_IR_CON);
if((size = getSn_RX_RSR(sn)) > 0)
if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE; /
loc_ret = wiz_recv(sn, buf, size);
if(loc_ret <= 0)
return STAT_RX_FAILED;
size = (uint16_t) loc_ret;
*rcv_size = size;
ret = STAT_SOCK_OK;
break;
case SOCK_CLOSE_WAIT :
loc_ret = wiz_disconnect(sn);
if(loc_ret != SOCK_OK)
ret = STAT_SOCK_NOT_OK;
break;
case SOCK_INIT :
loc_ret = wiz_connect(sn, destip, destport);
if( loc_ret != SOCK_OK)
break;
case SOCK_CLOSED:
wiz_close(sn);
ret = wiz_socket(sn, Sn_MR_TCP, any_port++, 0x00);
if(ret != sn)
if(any_port == 0xffff)
any_port = 50000;
ret = STAT_SOCK_NOT_OK; // TCP socket open with 'any_port' port number
//set auto keep alive every 5 sec
setSn_KPALVTR(sn, 1);
break;
default:
break;
return ret;
I get SOCK_ESTABLISHED and it runs OK.
wiznet_status = WIZNET_Run(SOCK_TCPS, read_buf, tcp_server_ip, PORT_TCPS, &TCP_RecSize);
But if I send something
if (wiznet_status == STAT_SOCK_OK)
if (wiz_send(SOCK_TCPS, messages_Q_Buffer, Q_RecvSize) == ERROR)
printf(“Error Sending Message\n”);
I get in uint8_t status = wiz_getSn_SR(sn); - status = 0x03 and it is invalid status – there are no such documented status.
