I am using W5500 module (not shield) with Arduino. I installed Ethernet2 library and I put example of WebServer to the Arduino.
Then serial output give “server is 255.255.255.255”
What is this problem?
I think the connection between the Arduino and the W5500 module is wrong. Check other register values using the code below.
Serial.println (Ethernet.subnetMask ());
Serial.println (Ethernet.gatewayIP ());
Now the connection is ok. But Server not showing in computer. I directly connect through Ethernet cable.
When I go to page it is show
ERR_CONNECTION_REFUSED
Is it a cable problem? Cross or nor?
Serial Output give
server ip 192.168.1.177
My home network is also 192.168.1.__ range.
Now it is connected thank you very much
