I have again a problem with my W5100 on the arduino 328P board.
When I connect to my own TCP-Server written in C#, then the Webclient connects at the first try.
But when I want to connect to my webserver, my client connects only after several (5- 15) tries.
I don´t no what the problem is, can somebody help me?
[quote]Edit: Can it be that the problem is the wrong port? I use port 23456
Which port should i use instead?[/quote]
When you do implement as client, you should be random port number as source port number.
When you fix the source number, Next connection can’t established.
