Hi there,
I’m using an ESP32 with ESP-IDF and a W5500 module to receive ArtNet packets streamed over Ethernet. The SPI interface is running at 20Mhz and each of two sockets is set to 8K.
While I’m able to get some packets, it seems the very frequently UDP packets are received incomplete or corrupt, which results in wrong values in the UDP packet header and the addressing to get our of sync with actual packet starts and ends.
I’m quite to using the W5500 but tried to follow the datasheet and examples I saw in both the Arduino Ethernet library and your IoLibrary on GitHub.
My reading code is quite simple and follows your example’s workflow for UDP:
esp_err_t EthernetDriverClass::read(int socketIndex, uint16_t port, uint8_t* buffer, size_t length, size_t* received, in_addr_t* remoteIp) {
if(this->sockets[socketIndex] == -1) {
ESP_LOGE(ETH_TAG, "Attempted to read from closed socket");
return ESP_FAIL;
// take semaphore
W5100.lock();
1. Check available data
uint16_t rd = getSnRX_RSR(socketIndex);
if (rd > 0) {
ESP_LOGI(ETH_TAG, "Available: %d", rd);
rd %= SSIZE;
// // nothing to do, no new data
if (rd == 0) {
W5100.unlock();
return ESP_OK;
2. Read packet header
uint8_t header[8];
// read packet header from current RX address
// read_data(socketIndex, state[socketIndex].address, (uint8_t*)&header, sizeof(header));
socketRead(socketIndex, (uint8_t*)&header, sizeof(header));
3. Parse UDP packet header
// get remote IP
memcpy(&state[socketIndex].remoteIp, (uint8_t*)&header, 4);
// parse UDP payload size
uint16_t payloadSize = (header[6] << 8) + header[7];
4. Read data
// check for invalid packets
if (payloadSize == 0 || payloadSize > SOCKET_MAX_PAYLOAD) {
ESP_LOGI(ETH_TAG, "Invalid packet: %d, flushing", payloadSize);
ESP_LOGI(ETH_TAG, "Payload: %d", payloadSize);
// state[socketIndex].address += rd;
payloadSize = 0;
} else {
// read_data(socketIndex, state[socketIndex].address + sizeof(header), buffer, payloadSize);
socketRead(socketIndex, buffer, payloadSize);
// state[socketIndex].address += sizeof(header) + payloadSize;
// write out data and remote IP
*received = payloadSize;
*remoteIp = state[socketIndex].remoteIp;
Update RX address
// apply mask
// state[socketIndex].address = state[socketIndex].address & SMASK;
// give semaphore
W5100.unlock();
vTaskDelay(1);
// If we get here, there's no data available or recv failed
return ESP_OK;
with socketRead implemented as:
void EthernetDriverClass::socketRead(int socketIndex, uint8_t* buffer, size_t length) {
uint16_t ptr;
ptr = W5100.readSnRX_RD(socketIndex);
read_data(socketIndex, ptr, buffer, length);
ESP_LOGI(ETH_TAG, "Reading: %d from %d", length, ptr);
ptr += length;
W5100.writeSnRX_RD(socketIndex, ptr);
W5100.execCmdSn(socketIndex, Sock_RECV);
With this code however, after a short amount of time (and variable number of packets received) the data seems to get either corrupted or incomplete, and the UDP headers are wrongly parsed.
Here is a log of a stream of equally sized ArtNet packets, each packet contains 512 bytes of data and 18 bytes of header, and the UDP header is 8 bytes:
I (10070) ETHERNET: IP address: 192.168.2.7 | |
I (10120) NETWORK: Got IP | |
I (10124) ETHERNET: Available: 1076 | |
I (10124) ETHERNET: Reading: 8 from 0 | |
I (10124) ETHERNET: Reading: 530 from 8 | |
ARTNET | |
I (10127) ETHERNET: Available: 538 | |
I (10130) ETHERNET: Reading: 8 from 538 | |
I (10135) ETHERNET: Reading: 530 from 546 | |
ARTNET | |
I (10158) ETHERNET: Available: 1076 | |
I (10158) ETHERNET: Reading: 8 from 1076 | |
I (10158) ETHERNET: Reading: 530 from 1084 | |
ARTNET | |
I (10162) ETHERNET: Available: 538 | |
I (10165) ETHERNET: Reading: 8 from 1614 | |
I (10170) ETHERNET: Reading: 530 from 1622 | |
ARTNET | |
I (10176) ETHERNET: Available: 2048 | |
I (10179) ETHERNET: Reading: 8 from 104 | |
I (10184) ETHERNET: Reading: 1 from 112 | |
I (10190) ETHERNET: Available: 3115 | |
I (10192) ETHERNET: Reading: 8 from 113 | |
I (10197) ETHERNET: Invalid packet: 0, flushing |
The first few calls receive all data correctly, with the first available call returning 1076 (538*2) and several subsequent calls also working well. The reading is split to reading the UDP header and following up with another read of the UDP datagram’s size which is 530 on all successful calls.
Notice how in the end of the log, available reports 2048, which is incorrect and is not divisible by 538, meaning data is either missing or the report is wrong?
From then on the reading loses track of the actual UDP datagrams in the buffer and tried to read headers from wrong places and can’t recover unless I reset the program or the sockets.
This happens within seconds of the program staring to run, but not in consistent places. As you can see from the pointer in the log, the datagram size is wrong when parsed, 1 then 0, all random numbers.
The issue doesn’t seem to be related to the buffer wrap-around, which was my original assumption and I’m at wit’s end in trying to figure this out.
Would appreciate your help!
Edit:
Just wanted to add some additional details:
this seems related to UDP packet RX pointer not at header but I seems to be unresolved there as well.
Resetting the socket by closing and opening it extends runtime but happens very frequently and causes the W5500 to eventually freeze and not be able to read until the board is power-cycled.
