According to the code above, it is normal for an interrupt to occur.
First I want you to check if udp data receive is done.
Also, I wonder how the interrupt row is checked.
void w5500RX() {
if (wizphy_getphylink() > 0) { //Check Ethernet cable up or down
switch (getSn_SR(w5500.socketNumber)) { //Get status of selected socket
case SOCK_UDP:
if (getSn_IR(w5500.socketNumber) == 0x04) { //Sn_IR_RECV -> RX interrupt
if (getSn_RX_RSR(w5500.socketNumber) > 0) { //If rx buffer is not empty
memset(w5500.rxMessage, 0, w5500.rxBufferLength); //Erase all buffer before receive
w5500.rxBufferLength = getSn_RX_RSR(w5500.socketNumber);
recvfrom(w5500.socketNumber, rxBuffer_ptr,
w5500.rxBufferLength, w5500.remoteIp,
&w5500.remotePort); //Receive command
for (int i = 0; i < (w5500.rxBufferLength - 8); i++) { //Copy message memory to struct
w5500.rxMessage[i] = *(rxBuffer_ptr + i);
memset(rxBuffer_ptr, 0, w5500.rxBufferLength);
free(rxBuffer_ptr);
break;
case SOCK_CLOSED: //If socket closed, try to connect again
socket(w5500.socketNumber, Sn_MR_UDP, w5500.localPort, 0); // 0 -> No flag need at UDP
break;
Falling edge interrupt working at mcu side I have tested already.
Yes code enter if (getSn_IR(w5500.socketNumber) == 0x04).
I can’t see any change on INTn pin. As I understand pin stays low until I clear interrupt. If pin fall, I will add clear interrupt.
