Below are functions to set wiz550io as TCP server
Fill free to use they are for MikroC IDE and dsPic in C Any improvemt and suggestion are welcome.
for debug resons I use Uart2 so first of all you have to
Uart2_Init(115200); // DEBUG port use uart2
U1MODEbits.ALTIO = 1; // clear the way for SPI
if you don’t like the messages to uart2 then comment the uart lines
to begine TCP server
do { // main loop start here
do{ // Socket 0 initialize
SocketRegister_WRITE(Sn_MR ,SelectSocket_0_Register,Sn_MR_TCP); //protocol = TCP
SocketRegister_WRITE(Sn_PORT0,SelectSocket_0_Register, SocketPort[1]); // set port number
SocketRegister_WRITE(Sn_PORT1,SelectSocket_0_Register, SocketPort[2]);
SocketRegister_WRITE(Sn_CR,SelectSocket_0_Register,SockCMD_OPEN); //give the open command
if(SocketRegister_READ(Sn_SR,SelectSocket_0_Register) != Sn_SR_SOCK_INIT){ //wait for the socket to come online
SocketRegister_WRITE(Sn_CR,SelectSocket_0_Register,SockCMD_CLOSE);
}while(SocketRegister_READ(Sn_SR,SelectSocket_0_Register) != Sn_SR_SOCK_INIT);
UART_Write_Text("Soket 0 opend at port : " );
Addr_Hi= SocketRegister_Read(Sn_PORT0,SelectSocket_0_Register);
Addr_Lo= SocketRegister_READ(Sn_PORT1,SelectSocket_0_Register);
Int_Addr=make16(Addr_Hi,Addr_Lo) ;
IntToStr(Int_Addr,IntTxT); UART_Write_Text(IntTxT); UART_Write_Text(" "); UART_Write(0x0D);UART_Wr_Ptr(0xA);
// wait until Socket 0 gose to Listen
do{
/* listen SOCKET
Sn_CR = LISTEN;
// wait until Sn_SR is changed to SOCK_LISTEN
if (Sn_SR != SOCK_LISTEN) Sn_CR = CLOSE; goto START;
SocketRegister_WRITE(Sn_CR ,SelectSocket_0_Register,SockCMD_LISTEN);
}while (SocketRegister_READ(Sn_SR,SelectSocket_0_Register) !=Sn_SR_SOCK_LISTEN);
// wait here until someone wanta to comunicate with you
do{
// if (Sn_SR == SOCK_ESTABLISHED) goto ESTABLISHED stage;
UART_Write_Text("Soket 0 now is at state : " );
i= SocketRegister_Read(Sn_SR,SelectSocket_0_Register);
ByteToStr(i,ByteTxt); UART_Write_Text(ByteTxt); UART_Write_Text(" ");UART_Write(0x0D);UART_Wr_Ptr(0xA);
UART_Write_Text("Soket 0 Sn_IR : " );
i= SocketRegister_Read(Sn_IR,SelectSocket_0_Register);
UART_Write_Text("Soket 0 number of bytes received : " );
Number_Hi= SocketRegister_Read(Sn_RX_RSR0,SelectSocket_0_Register);
Number_Lo= SocketRegister_Read(Sn_RX_RSR1,SelectSocket_0_Register);
intToStr(make16(number_hi,Number_Lo),IntTxT); UART_Write_Text(IntTxT); UART_Write_Text(" ");UART_Write(0x0D);UART_Wr_Ptr(0xA);
/* you have to watch Sn_IR not Sn_SR
Second methode of Establishment in TCP manual does not work (sn_SR==Sn_SR_SOCK_ESTABLISHED) DOES NOT WORK
I must watch Sn_IR o be con== 0x1
}while(SocketRegister_READ(Sn_IR,SelectSocket_0_Register)==0);
// now data are here -->prosses data
SocketRegister_READ(Sn_IR,SelectSocket_0_Register);
if((i & Sn_IR_CON)==Sn_IR_CON){
// you MUST write Sn_IR for : a) sn_SR become Established b) to can get number of byts arrived
SocketRegister_WRITE(Sn_IR ,SelectSocket_0_Register,1);
SocketInterrupt=SocketRegister_READ(Sn_IR,SelectSocket_0_Register);
SocketInterrupt = SocketInterrupt & Sn_IR_RECV; // 0x4 data received
while(SocketInterrupt==Sn_IR_RECV){ // proessess packet
SocketRegister_WRITE(Sn_IR,SelectSocket_0_Register,Sn_IR_RECV);
// transfer data to receive buffer
// read from socket 0 pointer len of received size
Number_Hi=SocketRegister_READ(Sn_RX_RD0,SelectSocket_0_Register);
Number_Lo= SocketRegister_READ(Sn_RX_RD1,SelectSocket_0_Register);
StartAddressPointer =Number_Hi * 256 + Number_Lo;
UART_Write_Text("Start Address Pointer: "); IntToStr(StartAddressPointer,IntTxT);UART_Write_Text(IntTxT);uart_write(0xD);UART_Write(0xA);
Number_Hi=SocketRegister_READ(Sn_RX_RSR0,SelectSocket_0_Register);
Number_Lo=SocketRegister_READ(Sn_RX_RSR1,SelectSocket_0_Register);
Sn_RX_ReceivedSize=Number_Hi * 256 + Number_lo;
UART_Write_Text("Received Bytes Len: "); IntToStr(Sn_RX_ReceivedSize,IntTxT);UART_Write_Text(IntTxT);uart_write(0xD);UART_Write(0xA);
WizEnablePin=0; Delay_us(2); // /SCS ACTIVE LOW begin SPI frame
i=((StartAddressPointer & 0xFF00) >> 8);
SPI1_Write(i);
i=(StartAddressPointer & 0x00FF);
SPI1_Write(i);
SPI1_Write(Select_Socket_0_RX_Buffer);
for (Len_of_bytes=0;Len_of_bytes<Sn_RX_ReceivedSize;Len_of_bytes++){
i= SPI1_Read(i); // read data this pointer forward
ReceiveBuffer[Len_of_bytes] =i;
WizEnablePin = 0x01; // /SCS end SPI frame
delay_us(2);
// increase Sn_RX_RD as length of len
StartAddressPointer += Sn_RX_ReceivedSize;
Split_Number(StartAddressPointer);
SocketRegister_WRITE(Sn_RX_RD0,SelectSocket_0_Register,Number_Hi);
SocketRegister_WRITE(Sn_RX_RD1,SelectSocket_0_Register,Number_Lo);
// set RECV command -->Sn_CR = RECV;
SocketRegister_WRITE(Sn_CR,SelectSocket_0_Register,SockCMD_RECV);
// examin the first 5 bytes and do
if(memcmp(ReceiveBuffer, "Get /", 5)) { // only GET method is supported here
showMainPage();
if(memcmp(ReceiveBuffer, "Get /sms", 8)) { // only GET method is supported here
SendSmsValues();
if(memcmp(ReceiveBuffer, "Get /set", 8)) { // only GET method is supported here
SendSetupPage();
/* do{
UART_Write_Text("Text received :");
UART_Write(ReceiveBuffer[Len_of_bytes]);
UART_Write(0xD);UART_Write(0xA);
}while(1);
// read Sn IR for while loop
and responce back with
void showMainPage(){
unsigned int Total_Bytes_Sent=0;
int len_to=0;
char msg1[]="<!DOCTYPE HTML PUBLIC '-//W3C//DTD HTML 4.01 Transitional//EN'><html><head><title>anemometer </title>"
"<meta http-equiv='Content-Type' content='text/html; charset=iso-8859-7'>";
// close page
char msg13[]="</tr></table></div></div></body></html>";
// start to send page
Total_Bytes_Sent= Write_Tx_Buffer(msg1);
SocketRegister_WRITE(Sn_CR,SelectSocket_0_Register,SockCMD_DISCON); // send disconect
if ((i & 0x2)==0x2){ SocketRegister_WRITE(Sn_IR,SelectSocket_0_Register,0x2); } // disconect
SocketRegister_WRITE(Sn_CR,SelectSocket_0_Register,SockCMD_SEND);
} // end of showMainPage()
unsigned int Write_Tx_Buffer(char msgString[]){
unsigned int sn_tx_wr=0;
unsigned int i=0;
// this function write the msgstring to module buffer and returns the legth of the string
Sn_TX_TxSize=strlen(msgString);
// write to TX_buffer at pointer
Number_Hi=SocketRegister_READ(Sn_TX_RD0,SelectSocket_0_Register);
Number_Lo=SocketRegister_READ(Sn_TX_RD1,SelectSocket_0_Register);
StartAddressPointer=Number_Hi * 256 + Number_Lo;
SPI1_Write(i);
SPI1_Write(i);
SPI1_Write(Selects_Socket_0_TX_Buffer);
for (Len_of_bytes=0;Len_of_bytes<Sn_TX_TxSize;Len_of_bytes++){
SPI1_Write(msgString[Len_of_bytes]); // write this pointer Tx_Buffer forward
delay_us(2);
Number_Hi=SocketRegister_READ(Sn_TX_WR0,SelectSocket_0_Register);
Number_Lo=SocketRegister_READ(Sn_TX_WR1,SelectSocket_0_Register);
sn_tx_wr=(Number_Hi * 256 + Number_Lo) + Sn_TX_TxSize;
Split_Number(sn_tx_wr);
SocketRegister_WRITE(Sn_TX_WR0,SelectSocket_0_Register,Number_Hi);
SocketRegister_WRITE(Sn_TX_WR1,SelectSocket_0_Register,Number_Lo);
// send command SEND
delay_us(2); // give some time
if ((i & 0x10)==0x10){ SocketRegister_WRITE(Sn_IR,SelectSocket_0_Register,0x10); } // send OK
return Sn_TX_TxSize;
