Hi ,
I am facing speed issue in my new design, its detecting 10Mbps after some time its detecting 100mbps / after multiple power ON its detecting 100Mbps( link was not stable every time mostly its speed detecting 10mbps). may i know the what is the exactly issue in my design.
You did not say if the problem persists if you connect to different devices at another end of the cable. I see you confused RX/TX at the jack, may not be a big problem because transformer is symmetrical, but will force endpoint device to function in cross-over mode. You are missing formal connection of C19 on the circuit diagram, but on the board it seems to be connected properly. Crystal is out of tolerance specification - you use 50 ppm instead of max 30 ppm. You did not separate digital and analog circuits with simple ferrite bead-based filter. Layout looks strange, in particular why you have put power loops on the top and bottom layers when you have power and ground planes. Power supply layout is not good - datasheet says to put ground vias, and you put then far away from the coil and Cout. You have put 0R resistors wherever possible - do you know they also have power rating? Are you sure R89 feels good by itself, and makes circuit after it feeling well?
All these will add to the overall quality of operation.
