Dear all:
I have the TCP protocol configured on the w5500 Ethernet chip and it works fine.But now I need to run Modbus TCP/IP on this Ethernet chip.I would like to ask the official WIZnet technical staff, is there any reference works or code to run Modbus TCP/IP protocol on W5500?
Looking forward to hearing from WIZnet’s official engineers.
No one answered?
Sorry for late reply.
The example you are referring to is on the WIZnet Github. You might want to check out the link below.
GitHub - Wiznet/WIZ550S2E-Modbus: Serial to Ethernet Module based on W5500 & Cortex-M0
Dear Matthew
Thanks for your reply.I am using this file officially for the first time, I would like to ask how to use this file on github. I can’t open it on keil.
For these projects, you will be viewing them in the LPCXpresso IDE or MCUXpresso development environment, not Keil.
To do so in Keil, you will need to port the src file yourself.
The URL below is how to run the Firmware project in LPCXpresso IDE or MCUXpresso.
GitHub - Wiznet/WIZ550S2E: Serial to Ethernet Module based on W5500 & Cortex-M0
Thank you very much for your reply, which is very helpful to me
