#include "main.h"
#include "dma.h"
#include "spi.h"
#include "usart.h"
#include "usb_device.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "wizchip_conf.h"
#include "string.h"
#include "w5500.h"
#include "loopback.h"
#include "socket.h"
#include "Atama.h"
#include "Eth_Func.h"
#include "Flash.h"
#include "dma.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
#define RxBufferSize 1024
uint8_t RxBuffer[RxBufferSize];
#define TxBufferSize 1024
uint8_t TxBuffer[TxBufferSize];
uint16_t size=0;
uint8_t a=0;
/* ------------------------------------------------------------------------MAİN DOSYASINDAN DEN ÇA�?IRANLAR DE�?İ�?KENLER-----------------------------------------------------------------*/
extern DMA_HandleTypeDef hdma_usart3_rx;
uint16_t size1 = 0;
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
void HAL_UARTEx_RxEventCallback(UART_HandleTypeDef *huart, uint16_t Size){
HAL_UARTEx_ReceiveToIdle_IT(&huart3, RxBuffer,RxBufferSize);
send(1,RxBuffer,Size);
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
uint8_t bufSize[]={2, 2, 2, 2};
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
HAL_Init();
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_SPI1_Init();
MX_USART3_UART_Init();
MX_USB_DEVICE_Init();
/* USER CODE BEGIN 2 */
/* ------------------------------------------------------------------------RS485 DE-RE BACAK PİNİ--------------------------------------------------------------------------*/
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_1,GPIO_PIN_RESET);
/* ------------------------------------------------------------------------W5500 AKTİVE KODLARI--------------------------------------------------------------------------*/
reg_wizchip_cs_cbfunc(cs_sel, cs_desel);
reg_wizchip_spi_cbfunc(spi_rb, spi_wb);
wizchip_init(bufSize, bufSize);
wiz_NetInfo netInfo = { .mac = {0xDA,0x01, 0xFE,0x00, 0x45,0xAA}, // Mac address
.ip = {192,168,1,68}, // IP address
.sn = {192,168,1,1,}, // Subnet mask
.gw = {255,255,255,0},
.dns ={8,8,8,8},
.dhcp =NETINFO_STATIC
}; // Gateway address
wizchip_setnetinfo(&netInfo);
wizchip_getnetinfo(&netInfo);
/* ------------------------------------------------------------------------Gelen Veri ve giden veri boyut size ayarı--------------------------------------------------------------------------*/
setSn_RXBUF_SIZE(1,8);
setSn_TXBUF_SIZE(1,8);
socket(1,Sn_MR_TCP,500,SF_TCP_NODELAY);
listen(1);
//------------------------------------------------------------------------- FREERTOS BA�?LIYOR-------------------------------------------------------------------------
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(getSn_SR(1)==SOCK_ESTABLISHED){
if((size = getSn_RX_RSR(1)) > 0){ // VERİ GELDİYSE............
recv(1, TxBuffer, size);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_1,GPIO_PIN_SET);
HAL_UART_Transmit_DMA(&huart3, TxBuffer,size);
size=0;}}
HAL_Delay(1);
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
Error_Handler();
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48|RCC_OSCILLATORTYPE_HSI
|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 1;
RCC_OscInitStruct.PLL.PLLN = 8;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN 4 */
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart){
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
HAL_NVIC_SystemReset();
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
All code as above.
Please help me.
