I’m programming on W5100S-EVB-Pico using this library(Wiznet/RP2040-HAT-C).
When I try to initialize the wizchip by below code, things go well when the ethernet cable is connected to a proper network.
But when the network is dead or ethernet cable is not connected, the process is stuck inside below codes.
wizchip_spi_initialize();
wizchip_cris_initialize();
wizchip_reset();
wizchip_initialize();
wizchip_check();
const wiz_NetInfo wiz_net_info = {
.mac = {0x00, 0x08, 0xDC, 0x11, 0x22, 0x33},
.ip = {IP_ADD_0, IP_ADD_1, IP_ADD_2, MY_IP_ADDR},
.sn = {255, 255, 255, 0},
.gw = {IP_ADD_0, IP_ADD_1, IP_ADD_2, 1},
.dns = {IP_ADD_0, IP_ADD_1, IP_ADD_2, 1},
.dhcp = NETINFO_DHCP
network_initialize(wiz_net_info);
How can I avoid this?
