Sometimes I get unexplained socket closures. I captured this one with Wireshark. The W550, my PC running Wireshark, and a network switch are connected with an ethernet 3-way port mirroring switch. The switch is connected to our router.
W5500 ip address: 192.168.1.11
Server ip address: 20.49.109.146
Packet 19: MQTT Publish message from server
Packet 20: MQTT PUBACK back to server
Packet 21: Re-transmission of PUBACK (only 23 msec later)
Packet 22: Ack from server (23 msec after re-trans)
Packet 23: RST from W5500 (only 23 msec after re-trans)
Shouldn’t the W5500 wait 200 msec before re-transmission?
Shouldn’t there be more than one re-transmission before closing the socket?
More troubleshooting is needed. As I understood your PC is a “server”. What your PC sees is receiving retransmission of the packet. It does not state who did the retransmission, it could be a switch on behalf of W5500. Connect PC and W5500 directly without any gateways and switches (putting them in same subnetwork of course) and try again.
