Hello, I am sorry I have to ask question again, Wiznet please reply. I asked similar question in one of previous threads, it remained unanswered.
I have receive operation serviced in interrupt routine. This means when interrupt occurs, I find out that it is RECV-related, and process data in the W5100’s receive buffer.
Imagine W5100 in TCP “established” state, or in UDP “sock_udp” state. Data came in, and I got hardware interrupt, went into interrupt handling routine, cleared RECV interrupt in Sn_IR, and is performing processing of received data. BUT in this processing routine I have got CPU interrupts enabled (I can not change it), and if W5100 will make another interrupt, all communication is messed, and even probably machine will crash.
The question is: if W5100 has got data and raised software and hardware interrupt, I cleared this interrupt using Sn_IR, may W5100 raise ANOTHER interrupt while I am working on its receive buffer?
Looking to the datasheet I guess that to let W5100 continue receiving data (and thus raise another interrupt for receive operation) C_RECV command is needed for socket. Until I issue it, no receiving and thus interrupt occurs.
But I need explicit confirmation of this behavior.
Please reply ASAP.
