I bought 3 your module wiznet810mj and I attempted work with it via SPI .
I use PIC18F452 which has hardewr SPI protocol. When I attempt read some register (example MR) I always get 0 from return same thing is when i write in some register.
I read all datasheet of w5100 and check out more time connected pins.
I first reset w5100 and wait some ms then enable SPI_EN and wait some ms and then send command in format f0adress (2B)data(1B).
I don’t know what can I do next???
Wiznet810mj which I got from you is fill with IP Subnet mask and enable PING. When I attempt fill MR register with 0 (because I want disable ping) I can’t.
A send my example code, maybe help you that tell me where I make wrong!
#include <18F452.h>
#DEVICE ADC=10
#use delay(clock=8000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PC,errors)
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT,NOSTVREN
#include
#include
#include
#bit SMP=0xFC7.7
#bit CKE=0xFC7.6
#bit CKP=0xFC6.4
#bit SSPM1=0xFC6.1
#bit SSPM0=0xFC6.0
#bit SSPEN=0xFC6.5
#bit CS=0xF82.2
#bit BF=0xFC7.0
#bit TRS3=0xF94.3
#bit TRS5=0xF94.5
#bit SSPIF = 0xF9E.3
void wiznet_init()
output_bit(PIN_C0,1); //PIN_CO connected to reset pin
delay_ms(10);
output_bit(PIN_C0,0);
delay_ms(10);
delay_ms(10);
SMP = 0; // input is valid in the middle of clock
CKE = 0; // rising edge is data capture
CKP = 0; // high value is passive state
SSPM0 = 0;
SSPM1 = 1; // speed f/64(312kHz), Master
SSPEN = 1; // enable SPI
CS = 1; // disable wiznet
int SPI(int d) // send character over SPI
SPI_write(d); // send character
// while (!BF); // wait until sent
//return SPI_READ(); // and return the received character
int send_wiz_command()
int arg3,arg2,arg1,arg0;
int pom=255;
// command string - fill mr registar with 0
arg3=0xf0;// make8(cmd,3);
arg2=0x00;//make8(cmd,2);
arg1=0x00;//make8(cmd,1);
arg0=0x00;//make8(cmd,0);
CS = 0;
SPI(arg3);
SPI(arg2);
SPI(arg1);
SPI(arg0);
CS = 1;
arg3=0x0f;// make8(cmd,3);
CS = 0;
SPI(arg3);
SPI(arg2);
SPI(arg1);
SPI(arg0);
pom=spi_read();
CS = 1;
printf("rez2 = %d
",pom);
void main()
int16 brojac=0;
output_bit(PIN_C1,0); // PIN_C1 - connected to SPI_EN
wiznet_init();
output_bit(PIN_C1,1); // PIN_C1 - connected to SPI_EN
delay_ms(5);
send_wiz_command();
petlja : goto petlja ;
Help me PLEASE!
