We are looking into using this chip to transmit UDP packets and I have some basic questions.
- Do the chip add any information to the UDP packet? For example, the header and checksum of the packet?
- I looked in the sample code and I couldn’t see how the chip select was being used for reading from the socket. To read, do I follow these instructions:
- Set the address pins
- Pull chip select low
- Enable Read
- Read data from data pins
- Disable Read
- chip select high
If that is the case, how do I know when the read data is valid?
- What about writing to a socket?
- Set address pins
- Set data pins
- Enable write
- Disable write
- Set chip select high
If this is the case, how do I know when the data has been written?
- What about read/writes from a buffer? Do I have to enable chip select and read multiple times?
