We are seeing an issue with the W5300 device where during a transmission of DATA packets in TCP mode, it seems that the Wiznet temporarily stops sending packets that have been copied to the TX buffer through the TX FIFO register.
We are using the W5300 device to send DATA packets to a PC over an ethernet LAN at 850Hz. Each DATA packet is 348 Bytes. This requires 348 * 8 * 850 = 2.4Mbps of throughput, well within the spec of the W5300. A hardware interrupt at the 850Hz rate triggers a handler where instrumentation data is sampled, the DATA packet is assembled and the packet is sent over a connected TCP socket on the Wiznet.
The TCP socket TX buffer is configured as 8KB (0x2000). The send routine is implemented as in the example code in the DS and in the ioLibrary. I am checking Sn_FSR and waiting for the Sn_CR to clear the SEND command at each send.
At some point in the transmission (sometimes at 10min, other times 30min, 2hrs or several hours) there is a delay in the transmission of packets that my application is not able to recover from (due to the real-time DAQ nature of the application, dropping frames is not an option). I have captured the event in Wireshark and the characteristics are always similar. Immediately preceeding the event, transmission seems normal: The Wiznet is receiving one ACK from the remote peer for each two DATA packets sent, thus the RTT for the two DATA packets alternate between 50us for the second DATA packet in a pair and and 1.2ms for the first. This is expected with a 850Hz transmission rate as the time delta between the DATA packets being copied into the TX buffer should be roughly 1.17ms.
During the event there is a delay in DATA packets being seen on the wire. Sometimes it is small (~3ms) and recovers but eventually the delay is large enough and the application stops. Immediately after the delay several DATA packets (and respective ACKS) are seen on the wire in rapid succession. I have modified the DATA packet to contain the value of Sn_SR (including the reserved MSB) and the Sn_TX_FSR register during the transmission (the register values are obtained just prior to the send() routine that copies the DATA packet into the TX buffer). Each packet shows a Sn_SR of 0x0117
(SOCK_ESTABLISHED and the 0th bit of the reserved MSB). The Sn_TX_FSR is at MAX or MAX-len freesize for the first delayed DATA packet where MAX = 8KB and len = size of one DATA packet. Each successive packet on the wire shows Sn_TX_FSR shrinking by len until it reaches 0x0b9c (2972 Bytes) after 15 DATA packets have been “sent”. The 16th DATA packet shows Sn_TX_FSR as 0x0000 where Sn_SR 0x0917 (SOCK_ESTABLISHED and the 3rd and 0th bits of the reserved MSB).
No retransmissions are seen on the wire since ACKs are eventually seen by the Wiznet before the RTO expires, but this is not fast enough for the real-time application which is always producing more DATA frames to send.
The TCP receive window on the receiving host is ~64KB and does not shrink before or during the event and all ACKs, once returned, are seen on the order of tens of usecs after the preceeding DATA packets.
I usually run the test with a desktop ethernet switch between the my sending device and my PC but I can reliably reproduce the issue with a wire connectied directly to the PC.
Are there any other registers or indicators that I should look into to continue debugging this issue? Any help would be appreciated.
Thanks
my send() source code here:
int diag_ntwSendBin(short nFd, unsigned short *buf, unsigned long len)
uint8 tmp = 0;
uint32 freesize = 0;
uint16 i;
// check socket
tmp = getSn_SSR(nFd) & 0xff;
if ((tmp != SOCK_ESTABLISHED) && (tmp != SOCK_CLOSE_WAIT))
return SOCKERR_SOCKSTATUS;
// check previous send
if (sock_is_sending & (1<<nFd))
tmp = getSn_IR(nFd);
if (tmp & Sn_IR_SENDOK)
setSn_IR(nFd, Sn_IR_SENDOK);
sock_is_sending &= ~(1<<nFd);
else if (tmp & Sn_IR_TIMEOUT)
return SOCKERR_TIMEOUT;
else
return SOCK_BUSY;
while (1)
freesize = getSn_TX_FSR(nFd);
if ((sock_io_mode & (1<<nFd)) && (len > freesize))
return SOCK_BUSY;
if (len <= freesize)
break;
// copy new data to internal TX memory
for (i = 0; i < (len / 2); i++)
*((volatile unsigned short *)Sn_TX_FIFOR(nFd)) = *buf;
buf++;
// set WRSR
setSn_TX_WRSR(nFd, len);
setSn_CR(nFd, Sn_CR_SEND);
while (getSn_CR(nFd));
sock_is_sending |= (1<<nFd);
return len;
