hi
I have one issue at my hend …
-I configure TCP protocol and everything else
-than issue OPEN socket command
at this point Sn_TX_RD gets written with some number ussualy > 1k, but the Sn_TX_WR is 0
-after issue CONNECT command Sn_TX_WR have the same value as Sn_TX_RD
is this normal ???
after that if i issue SEND command …even i do not write anything i receive >1k of data on on the server?
if i write some data to TX memory and send it, i receive this data + some garbage data from before
any idea ?
regards zorz
